I hope someone can help as my google skills have let me down.
My kids have had a serious mess with our V1 TV and I want to put it back to factory settings. I can do it on our BV7 but can't figure out or find how to do it on the V1.
Any kind should who can point me in the right direction?
Page 6 of the manual:
If you need to reset your television to default settings, then bring up the REGIONAL SETTINGS menu and select another country. You will be asked to confirm the reset. All settings will be deleted and you must go through first-time setup, follow on-screen instructions.
instructions.
