I have a BeoSound Moment and when i use the beomusic app, it generally works ok. however, if i try to use iOS music from he app, i can tap a playlist and the songs in the playlist are dimmed. they are not dimmed in the iPhone music app and work fine. thoughts on the problem? (i've tried restarting phone, etc).
BeoNut since '75
Yes. I bet you are correct. They are not downloaded and the beimusic app doesn't trigger the download
johnbrks:Yes. I bet you are correct. They are not downloaded and the beimusic app doesn't trigger the download
I have downloaded music from my Apple Music subscription to my iPhone 6 such that it is available from the phone without being on any network - wi fi or data - (in Apple Music the tiny phone icon with stick clearly shows against each track) yet it remains dimmed out in Beo music app. Is there a way to overcome this such that downloaded music from Apple Music will play though Beo Music app?
Did you find a solution?
MARKFS:Did you find a solution?
Has anyone here experience playing music from purchased music in the beomusic app and the application hangs after pressing the music in the said playist?
I thought the music from iTunes needed twonky media server to work. I don't have Apple Music, as Deezer came with my Beosound and I thought that I would give it a go.
My iOS music shows up but most is dimmed exactly as in the pictures shown in this thread.
I pay for apple match, and I thought this gave drm rights obviously not!
The main reason for my purchase of Beosound moment and Beolab 20 speakers was to get the best sound quality while my ears are still Ok. it sounds great with Deezer.
I avoid airplay , Bluetooth for fear of degradation of sound.
A couple of questions ,
What is the best way to get the absolute best sound, is it a beogram hooked up with line in?
Does anyone know if Apple does give drm rights on their match service?
I use iTunes Match as well........i have just checked an album that i uploaded (it has Uploaded status in the file info), and pretty sure the original source was a CD then ripped into iTunes......the album is downloaded onto my iPhone, and it does show up as available within the BeoMusic app.............just tried another album (different status in iTunes oil info...."Matched")....and that also works in the BeoMusic app, once i have downloaded it onto my iPhone.......
but i've had inconsistent results in the past with the BeoMusic app.....generally works ok now......think something goes wrong in its interaction with the (Apple) Music app..causing things to dim, when they shouldn't......sorry, not sure if that helps....
