Good evening,
If anyone could help me to know how replace light bulb on a Beosound 3000 ?
I don't find the process on websites and prefer not to try it on a wrong way,,
Thank's a lot for your kindly help.
Best regards
you must teke the front plate of the unit.
1- detach glass doors
2- detach black plastic behind glass doors
3. udse torx to un screw and detach the front plate.
and than you can change it.
easy .. :)
Mind the screw at the back for the loading mechanism.
yes and no...
you can only detach a metal rod from the front if you partly detach fron plate before that.
but it is easier if you take your rear cover of.
