I have bought old beovox S30 boxes to connect them to my grammophone plyer (LP) together with old Denon amplifier. Since B&O uses its own connectors have can I connect them to my Denon ?
Thanks for help,
Zoran
erjavecz: I have bought old beovox S30 boxes to connect them to my grammophone plyer (LP) together with old Denon amplifier. Since B&O uses its own connectors have can I connect them to my Denon ? Thanks for help, Zoran
Welcome to Beoworld !Please don't mix things up:B&O used DIN speaker plugs/sockets.They are the only standard plugs/sockets for home stereo speakers in the world.Everything else is non-standard.If your amplifier has non-standard speaker connections, you can make adapters, f.e. frombare wire to DIN female.Martin
Jacques
Hi Zoran,
Welcome to the Beoworld.
You need the 2 pol DIN plugs at the amplifier side. Something like this (if the amp has this type of connections):
At the speaker side you need the 2 pol DIN sockets. Something like this:
You can buy both type of plugs/sockets in every electronic shop e.g Conrad...
It is very easy to mount them to the speaker cables. Either you has to screw or to solder the wires on.
If you have further questions please ask.
Theomaster
Vintage Bang & Olufsen
