BeoSound Century + Beo1
This post has 5 Replies | 3 Followers
Wasti
Poland
Posts 125
Wasti Posted: Tue, Nov 10 2015 5:28 PM
Hello there,
I am wondering if the Beo1 remote does operate the Beosound Century? I have tried to reprogrammed it with the hints in the BeoWorld archived forum but I was only able to switch off the Century buy holding the standby bottom for approx. 2 sec. Please advise.
Best wishes,
Wasti
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Tue, Nov 10 2015 10:19 PM
Hi Wasti
Did you configure your BeoRemote One by adding "Beo 4 audio" to the list of products you want it to control?
A long button press of the stand by button will turn off every B&O product it sees.
Opman
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Tue, Nov 10 2015 11:22 PM
Opman:
Opman
Opman, I'm pretty sure Wasti is talking about the old beo1 remote (designed to control the BC1 / BV1) rather than the BeoRemote One.
I recall reading posts about switching it to send beo4 style IR commands so that it can be used to control other devices and seem to remember it being tricky to get it into this mode but can't remember the details (and I've never owned one).
Martin.
TWG
Posts 1,672
TWG replied on Wed, Nov 11 2015 10:00 AM
The old and beautiful, ergonomical Beo 1 needs to be reprogrammed to control other devices. BUT: It will only control other Beovision TVs. I had no luck with audio systems after reprogramming.
Wasti
Poland
Posts 125
Wasti replied on Wed, Nov 11 2015 3:15 PM
Thank you for your replies. Yes, I am talking about the all aluminum old Beo1 remote controller. The reprogramming works with the Beosound 2300/2500 but it does not want to work with the Century which is a shame...
stefan
200 miles from Struer
Posts 2,920
stefan replied on Wed, Nov 11 2015 10:10 PM
Beo1 is able to control all products in videomode, because it was originally designed for BV/BC1.
This include audio sources that are masterlinked to a BV (videomaster) set to V.OPT 2 and audiomaster set to A.OPT 0.
If your Beo1 is able to control a BC2300/2500 I assume it is set to A.OPT 2 which enables your BC to detect video commands.
BS Century only detects audio commands, so it won't work with your Beo1.
Hope this helps
Stefan
Page 1 of 1 (6 items) | RSS
