Hello,
Thank you.
What is the Problem with the 100 hz. does it make the Picture bad in that case.
What consoles did you Play with them?
thanks
Hi folks,
Here is a how to make a RGB to scart cable work and turn on that gorgeous slick looking arcade mode on your MX Model :)
thanks to Carsten for the heads up at https://www.facebook.com/Bang.Olufsen.Commodore/
In some cases the RGB to scart cable needs to be updated in order to make it work on more modern TV's.
On the Amiga scart site there is a total technical rundown on how to go about it:
http://www.ianstedman.co.uk/Amiga/amiga_hacks/Amiga_SCART/amiga_scart.html
The easy way is to buy a more modern and updated RGB to scart cable for your Amiga.
verified and working with Amiga 500 and Amiga 1000
http://www.ebay.com/itm/COMMODORE-AMIGA-A500-RGB-SCART-TV-CABLE-2-METRE-LEAD-/390349278880
cheers
MX8000, MX7000, MX6000, MS6000, 2*MX4000, MX3500
http://8bitlegends.com
http://cope-com.com
Not exactly Amiga or C64, but still...
I was having a look on a german B&O catalog from 1985 and noticed that there is a picture of a Beovision with a Commodore plus/4 computer.
Torben Larsen:In some cases the RGB to scart cable needs to be updated in order to make it work on more modern TV's. On the Amiga scart site there is a total technical rundown on how to go about it:
Old thread but continuing this one instead of creating a new one... Torben in terms of SCART cable did you opt for the above schematics using the default resistor values? I recently picked up a MX4000 to be used for testing some old Amigas and I did notice that didn't get any picture at all using an original CBM SCART cable and seen this schematic preciously but never came around to test the until this past weekend. Composite input via SCART gave me B/W:
