A little competition...
This post has 35 Replies | 3 Followers
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE Posted: Mon, Nov 16 2015 5:03 PM
It's been a little while since we've had a competition, so here we go!
B&O gave me a full-colour, high quality brochure for the BeoLab 90 - and I got the Bang & Olufsen Tonmeister Geoff Martin, the man behind the sound of the BeoLab 90, to sign it for one lucky winner!!
If you look carefully you can see the pen in his hand and the brochure on his lap. He gave me the brochure back but I didn't manage to snaffle his pen, so it's just the brochure you see in the image which could be winging its way to you soon!
9 LEE
Eastbourne, UK
Posts 7,218
So - here’s the question from the Tonmeister himself.
“What is in my hand?  I know it’s a half pint glass, but what specific use did I have for it at Bang & Olufsen..?”
Post your answers - and if nobody gets near I’ll drop a clue once a day until someone does.  For the record, it's got nothing to do with the BeoLab 90 for once!!
Good Luck!! Yes - thumbs up
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
vikinger replied on Mon, Nov 16 2015 5:46 PM
Listening to the neighbours.
Graham
Søren Mexico
Mexico City
Posts 6,411
Turning your finger on the glass rim will bring out a certain tone, Der Tonmeister used it for comparation
Brigantinus
Posts 140
He needed 12 of these glasses to convince the CEO that the Beolab 90s are going to be build. Now they are empty  Big Smile
Peter the Biker
Eastwestfalia
Posts 944
Geoff, you exposed this glass to a certain frequency of a pair of BeoLab 90s. Thus it gave a clear sound. If there had been a difference between the two speakers, this resounding would have been a little bit "dirty" and at least one speaker would have needed a little bit of tweaking. Left HugDrinksRight Hug Edit: I saw too late that it has nothing to do with BeoLab 90.
I don't think you tried to blast a glass by a resonating frequency because the glass is either too thick or you cared more for your ears than for special effects Broken HeartBeer
Peter the biker
danezro
Posts 106
danezro replied on Mon, Nov 16 2015 8:29 PM
Vibration and shattering of the wine glass in front of the BL90 when the tone matches the glass resonance.
badgersurf
Posts 539
Was going to go with the shatter of the glass, but as others have guessed that, I will go with the curves of the glass were used as a base for the curves of the speaker
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Tue, Nov 17 2015 9:37 AM
Okay. Todays clue is..
'It's about the sound'
Smile
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Tue, Nov 17 2015 10:11 AM
To demonstrate resonant frequency (eg as the ringing of the glass after it is tapped)?
bramble
Posts 397
bramble replied on Tue, Nov 17 2015 11:07 AM
You had a thirst !Lets have a Party !!!
Beovision 7 40 mk 5 ,beovision 6x3,   beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2,  5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
BeoBoy68
Alsace 🇨🇵
Posts 1,247
BeoBoy68 replied on Tue, Nov 17 2015 2:25 PM
The sound is a resonance phenomenon.
The glass produce a pure tone at 442 Hertz resonance frequency - for example.
If the speaker correctly reproduces the 442 Hz resonant frequency, the glass is broken by the pressure wave. So it is 121,4 dB.
Geoff Martins use a pint glass to control resonance frequencies of the speaker. Yes - thumbs up
badgersurf
Posts 539
Did Geoff fill the glass with a fluid then use it to see how much the lower frequencies made the fluid move (I am sure there is a technical term for that!) to get an idea of the bass thumping out?
Millemissen
Flensborg, Denmark
Posts 14,680
So - what is todays clue?
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Thu, Nov 19 2015 10:50 AM
Todays clue is...
"You could hear a pin drop...."
Lee
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Thu, Nov 19 2015 11:15 AM
Using the glass like an ear horn to make the inaudible audible?
Millemissen
Flensborg, Denmark
Posts 14,680
So WHAT is the glas for???
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Fri, Nov 20 2015 12:32 PM
Todays clue :
"Enter the 5's"
Dennis
Denmark
Posts 627
Dennis replied on Fri, Nov 20 2015 3:54 PM
He wanted to give a toast?
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Fri, Nov 20 2015 5:58 PM
9 LEE:
Todays clue :
"Enter the 5's"
Ever more cryptic clues Smile
Okay, so I can't think what "the 5's" might refer to other than the BL5's, but the development of these was before Geoff's time at B&O...
so, thinking more laterally, something which enters the BL5 mechanically is it's microphone, so perhaps this what this clue relates to?
The other obvious place microphones are used in within the cube (where you could also hear a pin drop), so was the glass used to increase measurement sensitivity to sounds in a particular frequency range there?
Martin.
Lee
Newcastle upon Tyne UK
Posts 734
Lee replied on Sat, Nov 21 2015 2:12 AM
Did they record and reproduce the sound of the glass breaking to see how lifelike it sounded?
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Sat, Nov 21 2015 10:48 AM
Lee:
Did they record and reproduce the sound...
First part is correct.  That's your clue for today Smile
tournedos
Finland
Posts 7,357
tournedos replied on Sat, Nov 21 2015 11:26 AM
9 LEE:
Lee:
The speakers have audible feedback on some setting, and that's the "ding" of that glass?
--mika
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Sat, Nov 21 2015 12:45 PM
tournedos:
Read the clues and you'll have the answer.. You're almost there!
Lee
Lee
Posts 734
Lee replied on Sat, Nov 21 2015 5:15 PM
Did they record and reproduce the sound of a glass being hit and compared it to a real one to see how lifelike it sounded?
Søren Mexico
Mexico City
Posts 6,411
They used the ping of the glass to adjust 5 drivers to the same frequency
Millemissen
Flensborg, Denmark
Posts 14,680
If the glas stays for 5 minutes on top of the speakers at a volume of 90, they have passed the test.
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Sat, Nov 21 2015 7:58 PM
Is the sound that is produced when a pin code is entered a recording of the glass being struck?
Lee
Posts 734
Lee replied on Sat, Nov 21 2015 9:01 PM
Is the sound produced when the 5s are calibrated a recording of the glass being hit?
Or when they are wirelessly connected do the 5s play the sound of a glass being hit?
BeoBoy68
Alsace 🇨🇵
Posts 1,247
BeoBoy68 replied on Sun, Nov 22 2015 4:22 AM
9 LEE:
Cheers Big Smile
Geoff drink a glass If Wine when the speaker is calibrated.
vikinger
Posts 5,422
vikinger replied on Sun, Nov 22 2015 7:51 AM
The 'Ping' of the glass is recorded at very high quality and is then played back via the BL5.
If the reproduced sound makes the glass resonate then that proves the quality of the speaker reproduction.
Graham
vikinger
Posts 5,422
vikinger replied on Sun, Nov 22 2015 8:58 AM
vikinger:
Graham
I should have said that the ping is played back as a sustained note and the glass resonance can be checked at different positions around the speaker.
Graham
vikinger
Posts 5,422
vikinger replied on Sun, Nov 22 2015 12:31 PM
vikinger:
vikinger:
Graham
Graham
Confirming the acoustic lens sound distribution.
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Sun, Nov 22 2015 1:48 PM
riverstyx:
WINNER !!! Lets have a Party !!!
Yes, Geoff told me he held that exact glass in front of a microphone, flicked the edge and recorded the sound, then took it (from memory) a couple of octaves lower, synthesised it using his magic powers, then made it the PIN Code entry confirmation for the BeoLab 5.
PM me your address and I'll get the signed BeoLab 90 brochure to you!
Well done to all who entered Smile
Lee
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Sun, Nov 22 2015 2:25 PM
9 LEE:
riverstyx:
Lee
Woohoo! Lets have a Party !!!
Thank you so much Lee, and Geoff, and everyone else who entered.
Martin.
Millemissen
Flensborg, Denmark
Posts 14,680
Well done!
Congrats.
Page 1 of 1 (36 items) | RSS
