Beomaster 5000, two speaker sets
hbjorkas
Posts 7
hbjorkas Posted: Mon, Jun 25 2012 7:38 PM
I´ve just got an old Beomaster 5000, and I have connected one speaker set to my living room, and one to the kitchen (hard wired straight into the Beomasters speaker set 1 and 2). Is there any way to choose which set of speakers that are active (today both sets are playing all the time).
Thanks.
elephant
AU
Posts 8,219
elephant replied on Mon, Jun 25 2012 7:54 PM
hbjorkas:
Thanks.
Congratulations on your purchase and welcome to Beoworld.
Just to check, you mean this system ? ==> http://www.beoworld.org/prod_details.asp?pid=353
Ideally you should get a link room interface so that the link room can be controlled and muted.
You should be able to mute the main room as well.
What remote control are you using ?
BeoNut since '75
MediaBobNY
Greenwich Village, NYC
Posts 1,106
You can mute speaker set #1, but not #2.  So decide which set (living room, kitchen) you wouldn't mind playing all the time, and use the speaker set #2 outputs for it.
hbjorkas
Posts 7
hbjorkas replied on Mon, Jun 25 2012 9:02 PM
That´s my system, yes. I´m using Master control panel 5000.
hbjorkas
Posts 7
hbjorkas replied on Mon, Jun 25 2012 9:03 PM
MediaBobNY:
Thanks. That helps a lot. It would of course be nice to mute the second set as well... :)
elephant
AU
Posts 8,219
elephant replied on Mon, Jun 25 2012 10:26 PM
MediaBobNY:
Are you sure ?
I thought if he got one of these ==> http://www.beoworld.org/prod_details.asp?pid=971
then he would be able to mute speaker set  #2 in the link room.
I think speaker set  #2 is always "on" because it expects the other end to have the remote control panel with its on/off, mute, and timer buttons,
BeoNut since '75
DMacri
United States
Posts 881
DMacri replied on Tue, Jun 26 2012 12:39 AM
That's it exactly. The MCL82 will give you control from your link room and works very well.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
Page 1 of 1 (7 items) | RSS
