Hi I recently got a remote mains switch (4001) from eBay , I plugged it in and it worked for 10 minutes ..then the relay went bang!!
I then inspected the unit and found that its 110v but fitted with a 240v plug , anyway I need to replace the relay and was hoping someone here might know where I can get one from.
any help would be much appreciated
thanks Alan
