Beocom 6000 MkII with PSTN Base
This post has 7 Replies | 2 Followers
pcsnw1
Posts 4
pcsnw1 Confused [*-)] Posted: Sun, Nov 22 2015 11:55 AM
We have recently changed telephone company and when we have switched over our phones will not work.
I have unregistered and reregistered the 2 handsets. I then reset the base and again re-registered the handsets. We can get incoming calls but when we ring any number at all it always calls our telephone suppliers help line??
I have tried a single plug in phone to the line and it works fine but when I plug our 6000 back in it says number not recognised or it calls our supplier?? Can anyone advise me what is happening please. Any help would be appreciated
Thank you
Raeuber
Germany
Posts 2,542
Raeuber replied on Sun, Nov 22 2015 1:02 PM
I would try to change the flash time.
pcsnw1
Posts 4
pcsnw1 replied on Sun, Nov 22 2015 1:17 PM
Hi, I am not sure what that is ? Can you just explain what I have to do and then I can give it a go?
David
Raeuber
Germany
Posts 2,542
Raeuber replied on Sun, Nov 22 2015 1:31 PM
Hi David,
please look at page 42 of the userguide (in german: 'Flashzeit ... Wählen Sie Lang, Kurz oder Individuell. Die richtige Flashzeit hängt davon ab, wie Sie Ihr Telefon angeschlossen haben.').
Hope this helps.
Räuber
pcsnw1
Posts 4
pcsnw1 replied on Sun, Nov 22 2015 3:17 PM
thank you. I have changed the flash time from short to long and no change. I have changed it back to short and still the same results. It just calls my phone providers help line.
Do you have any other ideas?
Kind regards
Raeuber
Germany
Posts 2,542
Raeuber replied on Sun, Nov 22 2015 3:31 PM
No, sorry, I have no other idea to solve your problem. Very strange!
Millemissen
Flensborg, Denmark
Posts 14,680
At least it calls the help line of the provider - what did they say to your problem?
pcsnw1
Posts 4
pcsnw1 replied on Sun, Nov 22 2015 4:00 PM
Hi, they said they will send out a BT engineer. The problem is that a normal plug in phone is working so they will then want to charge me as the fault is not on the line. They will be charging for something I already know?? Really strange.
I read that when you do a reset on the base it wipes all of your contacts etc but it did not do that when I did it. It just disconnected the base and I had to reconnect my handsets but they kept all of their information? Do you think maybe I have not done something correct here?
Page 1 of 1 (8 items) | RSS
