Hello,
The Essence remote control exists in 2 versions.
Which one is delivered with the product?
BTW, what is the "official" RPP ?
Kind regards,
Living Room BV Eclipse - BS Core - BL5 - BL8000 - LC2 x2 - Beo6
Lounge Beolink Passive - Cabasse Clipper - Beo4 Kitchen BL3500 - Beolink 1000
Bedroom BV9 - BL6000 (Thks Botty) - Beotime - LC2 - Beo5
Garden Lounge BC9000 - BG 6006 - BL4500 (Thks Botty) - Playmaker - Beolink 1000
Study BS1 - ML/NL Converter - BL2500 - Beo4 - Form 2 (Tks Botty) - Beoplay P2
The BeoSound Essence (2nd gen.)/MKII comes without the remote (i.e. only the hide-away box).Then you can choose either version of the remote (wall mounted or table variant), which suits you.
(the BeoSound Essence 1st gen./MKI was coming by default bundled with the wall mounted remote)
...or you could choose to connect an ir-eye to it - and remote control it with a BeoRemote One (or Beo4).
Millemissen: ...or you could choose to connect an ir-eye to it - and remote control it with a BeoRemote One (or Beo4).
Yes indeed, or even just use your smartphone / ipad and forget about other remotes all together (which is I guess is one of the reasons for not bundling it with a remote any more).
Martin.
My reason for getting the Essence was to have the "wheel".
The MK1 comes with the wall mounted wheel. But you can choose the table mounted for no extra cost. at least in the begining you could choose. And the table model can be wall mounted, only difference is that it does not have the Bang&olufsen logo.
Thanks for your advices.
Yann.
