Hi. I want to fit a rabbits ear aerial I recently purchased off ebay to my Beomaster 4500.
The aerial came with a fixing bracket. The aerial slots into the bracket fine, but the rear of the bracket is rounded and will not fit the Beomaster. I don't understand what the bracket would fit. I have attached photographs of the bracket.
Where can I get a bracket that fits? Also, the supplied screw is a machined thread type, but will not screw into the Beomaster. What screw would I need?
Thanks for any help
Nick
To my knowledge, there was never made an indoor antenna for the 4500... So if the add said it was designed for that, then I am afraid it was wrong.
There is no place to fix this antenna on the Beomaster
/weebyx
Hi, thanks for your help.
I have just read the manual, which always helps, and it says that a bracket is available, part no 3152006, so I'll see if I can track one down.
NickNike: Hi, thanks for your help. I have just read the manual, which always helps, and it says that a bracket is available, part no 3152006, so I'll see if I can track one down. Nick
You are correct :)
I have learned something new today :)
/Weebyx
I have too - never heard of that before ;-(
My 1970's BM2000 has a block on the back for attaching the rabbits ear aerial. The rectangular base block of the rabbits ear clips into the block on the BM?
I don't recognise the aerial in this thread as being for a BM.
Graham
vikinger: My 1970's BM2000 has a block on the back for attaching the rabbits ear aerial. The rectangular base block of the rabbits ear clips into the block on the BM? I don't recognise the aerial in this thread as being for a BM. Graham
The aeral looks like it fits the 2300/3000/3200 glassdoor systems..
Weebyx: The aeral looks like it fits the 2300/3000/3200 glassdoor systems..
Yes... its for the 2300 etc..
http://sound-affair.com/bang-olufsen-rabbit-ear-aerial
Sur votre photo, il s'agit d'un kit d'antenne pour les beosystem 2500 et 2300 et Ouverture.
Pierre Domoticloud
