Beoplay A6
This post has 8 Replies | 0 Followers
Maurice
Posts 108
Maurice Posted: Wed, Dec 2 2015 6:58 PM
I've just recently set up my A6 via pairing with my iPad and was wondering if it's at all possible to connect it to my Beovision 8/40 as a extra speaker, I realise it's only mention as a wifi speaker and I knew that on purchase but would it be at all possible? any ideas anyone.
Regards Maurice
mawheele
Posts 258
With the more recent BeoSystem 4 based TVs the answer would be yes. However I don't believe its possible on a BS3 based product.
mawheele
Posts 258
Hold on a second. Thinking again, you could potentially use the new line-in capability that just came in the new firmware.
Not sure how it works, but I think that is a definite option.
Simonbeo
Posts 1,451
You mean you can add a pair of A6s to a V1?
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
Millemissen
Flensborg, Denmark
Posts 14,680
You probably could use one of the scart connections.
They would have a line-level output.
Use a scartadapter with R/L out.
However, I am not sure, whether there would be a sound delay problem, when the A6 processes the sound of the line-in.
rfrichg
Posts 36
rfrichg replied on Thu, Dec 3 2015 7:20 AM
Correct you would have a problem with delay. Because it is not possible to put it in local play mode. It is always sending sound to the network this introduce a delay so multiroom is not misallinget
petrosbeli
Posts 64
Yes, you can connect a TV to the line-in of the BeoPlay A6. But you have to enter the BeoSetup settings and disable the latency on the line-in. See here: http://bogo.custhelp.com/app/answers/detail/a_id/7063/kw/7063
Maurice
Posts 108
Maurice replied on Thu, Dec 3 2015 8:39 PM
Guys thanks very much for the info and the number of replys it's very much appreciated
rfrichg
Posts 36
rfrichg replied on Sat, Dec 12 2015 8:53 PM
Great, to know that this is possible now, it was not in the begning
Page 1 of 1 (9 items) | RSS
