Connect beolab to Loewe product possible?
mivsbai
Posts 77
mivsbai Posted: Tue, Jun 26 2012 6:11 PM
I plan to connect beolab speakers to Loewe products. I know in a normal set up, I need a av processor to handle surround sounds for beolab speakers. However, I have noticed Loewe TV, Loewe MediaCenter and Loewe MediaVision3D have inbuilt sound processor can handle surround sound.
My question is is there anyway to use Loewe products act like an AV receiver for beolabs? What cable or adapter would need? And how is the sound quality and surround sound handling affect?  Has anyone done this before?
Many Thanks
Heribert
Vorarlberg / Austria
Posts 804
Heribert replied on Tue, Jun 26 2012 8:09 PM
Works really without problems. You will need a Loewe plug converter. This converts from their audio out to cinch. From this cinch you use a cable to Powerlink for your Beolabs.
Just the surround processor of Loewe is not as good as the B&O one.
BV 11-46  / Beoplay V1 -40 / Apple TV 1+3 / Beosound Essence MK2 / BL3 / 2* BL11 / BL 6000 / BL 12-1 / BL 2000 / 3 * Beo4 /BL Converter 1611
mivsbai
Posts 77
mivsbai replied on Wed, Jun 27 2012 12:02 AM
Hello Heribert,
Thanks for your reply first, do you know where can I get the Loewe plug converter? And the Loewe plug converter can connect to Loewe mediavision 3D or Loewe TV?
mivsbai
Posts 77
mivsbai replied on Wed, Jun 27 2012 12:04 AM
Forgot to mention , does the Loewe plug converter have front, rear and subwoofer socket for beolab speakers?
Heribert
Posts 804
Heribert replied on Wed, Jun 27 2012 12:32 PM
Hi Bai,
You can get the plug/cable at your Loewe Dealer, it is an official Loewe product. It has all 5.1 plugs plus a white plug, where I think it is for power supply of a sub… With the Loewe Plug you need to put the BL to “LINE Mode”, then they turn on, when a line signal comes.
The change in speaker mode does not do anything to them (on short term, but the switch off after some time without signal). For me (as just owning B&O) it was surprising, that a stereo TV programm just activated the two Beolab fronts, but not the center (Loewe TV Speaker). But the dealer confirmed this is OK.
Kind regards,
Heribert
Page 1 of 1 (5 items) | RSS
