hi,
I would appreciate if anyone could help me get the statistics on a BV4-50 MK3 ( with Beosystem3)!
I have a BV4-50 MK1 ( with Beosystem1) and to get the statistics i do this sequence: TV MENU and then 0 0 GO and it works. However if i try to do the same thing on the MK3 it does not work.
Thanks in advance!
just found the sequence:
is Menu Menu 0 0 GO
thanks anyway!
