Beolab Penta Mk1 Mk2 Mk3. Why do you love them so much? Please share! Tell your story.
This post has 86 Replies | 6 Followers
Stereomensch
Posts 322
@PeterPan:
so you changed the chassis to visaton?
Did you change the crossover, too? I don't know much about crossovers, but as far as I know, you have to modificate the crossover?
The visaton chassis should have a better quality, is the sound different from the ITT chassis?
@ Steve:
Do you still have the redline speakers? Did you compare the rl 140 with the Pentas?
Peter Pan
Posts 2,088
@ Stereomensch
My speakers are from the start BeoVox Penta.
Stereomensch
Posts 322
Has anyone of you ever tried the modifications of our member "die Bogener"?
I think he changed the crossover a bit?
hfinette
Posts 34
hfinette replied on Wed, Jul 11 2018 6:44 PM
Der Umbau ist der Hammer...
Christophe
Cape Town
Posts 94
Hi BeoWorlders,
I'm glad to see this thread, I'm the happy owner of a pair of BeoVox Pentas that I bought 6 years ago, paired with a Rotel IcePower amplifier until .. 2 days ago. The Rotel RB1510 was a 2x60 W power amp and was already delivering - I thought -  beautiful sound to the Pentas.
And then 2 days ago, a hi-fi dealer came to my place to make me try 2 other amps, a NAD2700 rated at 150 W and THX certified, and another esoteric amplifier from Vatiros (made in Thailand, huge mono blocks rated at 120 W).
After trying the Nad, then the Vatiros, I paid him for the Vatiros mono blocks and am rediscovering all my albums ! The dealer was with me when I played my test playlist and was looking for a sub all around the place.. I told him "there's no sub, just a DSP with room correction", much like what BeoLab 5 does.
My Pentas were renovated inside and outside: of course the midrange drivers were reconed, all drivers were silver-soldered to the internal wires, all filters were upgraded with new and better capacitors, and the black frets were replaced as well.
I'm using a DSPEAKER Anti-Mode DSP/room correction DAC that makes the Pentas go down to 35 Hz at -3 dB, and also removed their typical 100 Hz "bump".
The stellar prices on the new BeoLab speakers makes me want to keep them for as long as possible, not to mention the fact that they seem to have been designed to fit my windows..!
Svenni
Berlin, Germany
Posts 48
Svenni replied on Thu, Jul 12 2018 4:35 PM
Would love to hear more about your DAC setup!
Beoplay A2
Beoplay Earset
Beoplay H6 (Gen 2)
Beoplay S3 (pair)
Beoplay S8
Beovox CX50 (2 pairs)
Beovox RL 6000
Howzit
Posts 94
Howzit replied on Sun, Jul 15 2018 9:22 AM
I second that, would love to hear more about the DSP and DAC setup!
Beolab 9 | Beolab 8000 | Beolab 6000 | Beolab 2 | Beolab 3 | Beosound 9000 | Beoplay A9 | Beomaster 8000 | Beovox M75, / S75, / S45.2
Millemissen
Flensborg, Denmark
Posts 14,680
Howzit:
You can read more about the DSPeaker here:
http://www.dspeaker.com/
http://www.theabsolutesound.com/articles/dspeaker-anti-mode-20-dualcore-digital-signal-processor/
Stereomensch
Posts 322
I want to repair my new old pentas.
Audiofriends from the netherlands sells sicken made of foam and of gummi (rubber)?
Which one should I take? Is there any difference between them?
Gummi (Rubber):
https://www.repairyourspeakers.com/index.php?item=bang--amp--olufsen-beovox-beolab-penta---reparaturset-gummi&action=article&group_id=10000016&aid=410&lang=de
Foam: (Schaumstoff)
https://www.repairyourspeakers.com/index.php?item=b-o-bang--amp--olufsen-penta---reparaturset-schaumstoff-sicken&action=article&group_id=10000016&aid=2184&lang=de
DMacri
United States
Posts 881
DMacri replied on Wed, Jul 18 2018 11:28 AM
Foam is the original and will ensure a close match to the original specifications, so may be the right choice for authenticity. I bought the rubber surrounds because I plan to keep these speakers into retirement and I don’t want to have to reform again in 15 - 20 years. The rubber surrounds seem to be fine and will remain flexible for years to come. I am hoping they will not impact the sound too much. So it comes down to longevity over authenticity.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
hfinette
Posts 34
hfinette replied on Wed, Jul 18 2018 10:30 PM
Die Schaumsicken von Audiofriends kann ich sehr empfehlen, habe gerade 16 Mitteltöner damit repariert...
Stereomensch
Posts 322
Danke für Deine Antwort. Ich werde heute noch bei Audiofriends kaufen.
Dann am Wochenende ein Bild von der Weiche machen und bei Dillen die restlichen Teile bestellen Cool
Bei den Metallteilen habe ich nur einen Defekt, mir fehlen bei beiden Lautsprechern hinten diese schmalen Streifen.
Ich glaube ich lass das so, sieht eh keiner, oder....
hfinette
Posts 34
hfinette replied on Fri, Jul 20 2018 6:47 AM
Die Frequezweichen und Verstärkerumbauten habe ich nach der Anleitung vom "Die_Bogener" gemacht, das ist schon der Hammer wie die Pentas danach klingen. Teile habe ich von Hellsound und Conrad bezogen. Du wirst deine Freude an den Pentas haben...
hfinette
Posts 34
hfinette replied on Fri, Jul 20 2018 6:48 AM
Die Frequenzweichen und Verstärkerumbau habe ich nach der Anleitung vom "Die_Bogener" gemacht, das ist schon der Hammer wie die Pentas danach klingen. Teile habe ich von Hellsound und Conrad bezogen. Du wirst deine Freude an den Pentas haben...
Stereomensch
Posts 322
Super!!!
Sag mal wo finde ich die Anleitung der Bogeners?
Gruss Christian
hfinette
Posts 34
hfinette replied on Fri, Jul 20 2018 8:41 AM
im alten Forum
https://archivedarchivedforum2.beoworld.org/forums/t/5850.aspx?PageIndex=1
der Weichenumbau bezieht sich auf MK 2 oder 3, die Weichen der MK1 sind wohl etwas anders, die Bilder sind leider nicht mehr vorhanden...
ich habe Folienkondensatoren von Intertechnik MKT Radial 160v und WIMA's verbaut, für den Hochtonbereich habe ich 6,8µf  WIMA verbaut.... ich liebe die hohen Töne ;-)
carlito
Posts 239
carlito replied on Fri, Jul 20 2018 10:02 AM
hfinette:
im alten Forum
Kannst du hier noch eine Auflistung machen welche Teile zu ersetzen sind und mit welchen Teile du diese ersetzt hast.
Nur Teile der Weiche oder auch Teile des Verstärkers?
Besten Dank
Stereomensch
Posts 322
Die Holländer in diesem Forum diskutieren die gleiche Frage:
Smile
Hej igen
Forvent at mellemtoneenhederne skal skiftes. Der er 8 stk. De koster 400-500 kr. pr. stk. Kan købes hos BB elektronik. BB i Humlebæk kan sikkert også renovere pentaerne. Sikkert også Bremdal i Stuer..
SBR renoverede mine pentaer MK II og opgraderede dem til MK III (Den berømte modstand) Monteringen af det grønne display gjorde jeg selv.
Nedenstående komponenter kan købes hos Brink Elektronik
Kondensatorerne, der skal skiftes er:
Mellemtone filter
C1: 22 uF 10% 35 V
C2: 8,2 uF 10% 35 V
C3: 82 uF 15% 35 V
C4: 3,3 uF 10% 100 V
C5: 10 uF 10% 35 V
C6: 680 nF 10% 63 V -  kaldes 0,68 uF
C7: 680 nF 10% 63 V -  kaldes 0,68 uF
C8: 22 uF 10% 35 V
Bas and dikast filter
C1: 68 uF 10% 35 V
C2: 220 uF 20% 35 V
C3: 47 uF 10 % 35 V
C4: 2,2 uF 10% 100 V   (tweeter)
C5: 3,9 uF 10% 100 V   (tweeter)
C6: 680 nF 10% 63 V -  0,68 uF   (tweeter)
mvh/Fritz
Hier gefunden:
https://archivedforum2.beoworld.org/forums/t/33375.aspx
es geht wohl darum, dass die Frequenzweiche mal geändert wurde und nun mehr und bessere Mitten halt als vorher:
Opgraderingen er i mellemtone delefiltret nemlig R1 der oprindelig var 3.3 ohm men blev ændret til 2.2.
hfinette
Posts 34
hfinette replied on Fri, Jul 20 2018 11:21 AM
in dem o.g. Thread ist alles beschrieben, ich kann es aber gerne noch einmal hierhin kopieren.
BOARD 14:
This board is responsible for the tweeter and the bass section.
The tweeter uses C4 and R3. C4 is original 2.2uf and can be modded to 4.7 - 5.6 - 6.8uf. I like 5.6uf Wima. The picture shows a 4,7uf intertechnik. It is a little bit "soft".
R3 can be set to 0 Ohm. it can be a wire bridge next to the big coil.
All other parts were replaced by the same values by Intertechnik MKT foil capacitors. They are sold in germany by Conrad Electronik. I have tested also some other types, in the bass section i found no difference between MKS, MKT ... just the price was very different. The Intertechnik are not soo expensive and fit pretty good on the boards.
C4 habe ich 6,8µf verwendet
Board 15.
It is responsible for the mid's.
The resistor R5 can be set to 0 Ohm by a small wire bridge, the mid's become loader.
All other capacitors have the same values like original. The C1 = 27uf is replaced by 1x22uf and 1x4,7uf, this value is hard to get.
für den C1 habe ich den MKTA250 von Intertechnik in 27µf verwendet
das ist die Beschreibung von Martin "Die_Bogener"
hfinette
Posts 34
BOARD 14:
Board 15.
hfinette
Posts 34
hfinette replied on Fri, Jul 20 2018 11:28 AM
beim Verstärker ist weniger zu machen.
Replace:
C1 = 4,7uf
C2 = 4,7uf
C5 = 2,2uf
C25 = 10uf
IC2= LF353
Use highquality non magnetic Wima MKS-2-5 instead of the standard eletrolyt capacitors (Wimas are the 4 red blocks...)
Use an audiophil OPA2132 or OPA2134 (better...) OPAMP on IC2.
Stereomensch
Posts 322
Der Unterschied zwischen den Versionen ist wohl, dass die späteren Pentas einen Textilhochtöner haben.
Gruss Christian
@ Dillen: Bitte melde Dich mal bei mir. Danke.
pauljrog
Posts 92
pauljrog replied on Sun, Jul 22 2018 9:32 AM
I love the look of the Pentas, last year I was seriously considering purchasing a pair.....but......in my opinion although they are great speakers they are really old, although you can get them reformed etc, they are still old.
Luckily for me I was in a position I could purchase a pair of Beolab 5's which were a few years old with 3 years b&o warranty.
I must say the lab5's sound soooo very good, just sublime. I've had them for just under 1 year and still everytime I hear them they just blow me away!!!!!
Stereomensch
Posts 322
My pair of pentas are in a great condition, without an exception.
Both steel stripes at the back are missing? Any ideas how to solve this problem?
thanks in advance.
Hey Leute,
bei meinen Pentas fehlen hinten diese dünnen Edelstahlstreifen.
Hat einer eine Idee wo man so was herkriegt? Bei B&O bestimmt nicht, oder? Wahrscheinlich ist das auch zu teuer?
Gruss Christian
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Wed, Jul 25 2018 10:09 PM
Stereomensch:
Holländer?
I beg you, please...
What is the goal?
The original warm and soft sound?
A modern, shrill and sterile sound? (call it audiophile if you want).
Expensive capacitors that (won't improve sound but) would perhaps make you feel good?
You also emailed me and I gave you my advice regarding the choice of capacitors, the choice of midrange surrounds etc.
What is it you are trying to achieve?
What is the current condition of your speakers?
Do they have apparent problems?
Have they been messed with?
Are they off-spec?
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Wed, Jul 25 2018 10:30 PM
Dillen:
Holländer?
I beg you, please.
Ever done a blind test? I did, with several unkown people with a set with 1 penta modified and 1 without.
The difference was heard within seconds.
Why does it make a difference when changing the pre-audioline with mks2’s and an Opa(which is confirmed here on site) and making an investment in better (and therefore more expensive) capacitors on the filters not?
Refreshing the filterboards will give a better result with standard components. Certainly  But adding the extra in better will give you a better experience
You might give it a try.
Investing in the most expensive components will then not much improve the result above the better versions.
Dillen
Posts 13,191
Dillen replied on Wed, Jul 25 2018 10:38 PM
I use the OPA... modification too.
Not really a question of sound quality as such, but rather a matter of better signal/noise ratio.
Replacing (some) capacitors in the signal path in the preamp stages with foil caps will also improve things a bit, mainly because
B&O chose to use electrolytics rather than tantals (or polyester caps) which are better when it comes to these tasks.
Polyester (and tantals) doesn't produce a burst of noise every time charging and discharging begins. It's not a lot but enough to matter
when followed by a power amplfier with several dozen times of amplification.
hfinette
Posts 34
hfinette replied on Sun, Jul 29 2018 11:20 AM
the Mod on the Pentas will give you not a shrill sterile Sound ! it will let you hear clear voices and Instruments and there are a lot of Instruments you can't here with the original Setup but with the modded Pentas.
I have 2 Set's of Pentas here side by side one modded and one original, i invite everyone here to listen to the difference...
Peter Pan
Posts 2,088
Peter Pan replied on Sun, Dec 15 2019 3:01 PM
Can you send pictures of your BeoLab Penta - THANK YOU. Yes - thumbs up
pauliander
Posts 81
The last 3 years I have not used my pentas and only listened to Beolab 5s and homepods. Then 3 months ago I have installed again my pentas in the hope they were still ok. I was truly surprised how good they are. That good that I currently question myself on the investment made in the Beolab 5s...Wink
luisimoes
Posts 1
luisimoes replied on Thu, Dec 19 2019 1:12 AM
Good morning everyone,
I am new to this club, I have some questions, I am thinking of buying some B&O speakers, I have two possible deals, some Penta MKIII for 250 €, needing a good maintenance, or some BeoLab 8000 for 600 €; that are like new.
What purchase do you recommend? I personally prefer the Penta III ... the second question, given that these speakers go to an office that is also a movie theater, would I like to know if I can connect my OPPO 105 directly to B&O? My goal is to get OPPO to connect to B&O via coaxial digital cable, or stereo RCA, and also connect OPPO to my AV Onkyo TX NR 818, to connect the center speaker and other surround speakers. Finally ask you if this is the best solution and what cables do I need?
I await your feedback
Thank you
Peter Pan
Posts 2,088
Peter Pan replied on Thu, Dec 19 2019 8:03 AM
Hi luisimoes. You will probably need - https://translate.google.com/
Look here.
bramble
Posts 397
bramble replied on Thu, Dec 19 2019 8:09 AM
Good morning
I managed to save a pair of mk1's from landfil, recovered and new foam surrounds fitted.....brilliant , they haven't missed a beat. They now sit in the " man shed" and supply brilliant sound all summer long.CoolWhistleBig Smile
Beovision 7 40 mk 5 ,beovision 6x3,   beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2,  5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
luisimoes:
Thank you
Good morning luisimoes,
Welcome to Beoworld!  Please feel free to get in touch via my sponsor link at the foot of the page with the full list of products and speakers that you wish to connect, then I can help you to get everything working together.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Peter Pan
Posts 2,088
Peter Pan replied on Sat, Dec 21 2019 12:56 PM
pauliander:
That good that I currently question myself on the investment made in the Beolab 5s..Stick out tongue.
@ pauliander.
With my opinion of B&O Penta, that is a good conclusion you have come to. Smile Thumbs Up
Peter Pan
Posts 2,088
Peter Pan replied on Tue, Dec 24 2019 9:59 AM
To everyone at BeoWorld -
Stereomensch
Posts 322
This is an old addvertisment that I found in an old German magazin:
Stereomensch
Posts 322
This is my set. A pair of Penta mk3, a beovision 10 and a Beomaster 7000 + Beogram CD 7000.
The pictures are pretty bad :(
Peter Pan
Posts 2,088
Peter Pan replied on Wed, Mar 18 2020 9:54 AM
Lifestyle - Idea
Stereomensch
Posts 322
I love the pentas, but we never discussed about the dimensions of the room.
What do you think, what is the size of the room for the pentas to work best?
20-45 qm?
Page 2 of 3 (87 items) < Previous 1 2 3 Next > | RSS
