Hi I had a pair of Pentas in my flat and they were in a fairly large room with high ceilings and sounded great, I took them to my bungalow intending to have a listening room in my study which is much smaller with lower ceilings and they sounded great there but I couldn't play them loud as too close and way to loud for the room. I was lucky enough to get a pair of BL8000 very cheaply and they sound much better in the smaller room so will be taking the pentas back to the flat this weekend
Has anyone else noticed a big difference in performance based on room size? I know that when i had BL4000s in the flat I was disappointed with their performance and the Penta's blew them away, I am now wondering if it was just the size of the room and wether or not I should get another pair of BL4000 for the sitting room or BL6000? In that room they will only be used as background music instead of having music come through the BV8. I guess I could always try but wanted to see if others had had similar experiences.
That is why I (and a lot others) allway say: 'try the speakers at your own place', when being asked is this or that speaker good for me....
But generally no one can expect a 'small' speaker to give him the same (good) experience as a 'bigger one' in a big room and vice versa.
Much of the disagreement about, whether this or that speaker is good (!), comes from the fact that people are listening to the speakers in different rooms. But not only the size of the room matters - listening position, furniture, carpets, listening preferences etc all have an influence.
P.S. Maybe that will change a bit in the future, when we see (more) speakers with 'Room Compensation' from B&O.
