A simple thing - Alarm/Clock/Radio solution?
This post has 12 Replies | 2 Followers
Greg
Posts 24
Greg Posted: Sat, Dec 5 2015 3:22 PM
So we're looking for an alarm/clock/radio, but literally everything out there seems to be cheap plastic rubbish.
Would be great to find a B&O or similar quality thing, well made from good materials - but I think the only B&O product that might have suited was Beosound 3 which is now discontinued and it's hard to find a perfect second hand one... also is it actually any good as an alarm clock??
Any ideas/opinions very welcome!
Greg
PS most recent one we have tried was Revo SuperSignal which is sort of OK to look at and sounds good, but (ironically) not great at picking up an FM signal and the alarm setting process is stupidly complex.
Razlaw
Posts 4,345
Razlaw replied on Sat, Dec 5 2015 3:42 PM
When it was available, the Bedtime alarm clock was wonderful. While it was just an alarm clock, it could turn on another piece of B and O equipment when the alarm sounds.
TWG
Posts 1,672
TWG replied on Sat, Dec 5 2015 9:26 PM
If you want to activate B&O equipment or just wake up to the increasing chime signal of it, try to get a 2nd hand or new
Bang & Olufsen BeoTime
Userguide:
http://www.bang-olufsen.com/de/customer-service/product-support/accessories/various/beotime
Pictures:
http://www.slashgear.com/bang-olufsen-beotime-clockremote-thinks-its-a-flute-1549447/
Video:
https://www.youtube.com/watch?v=qtEkIPQSLV8
It's just timeless...
rxcohen
New York
Posts 201
rxcohen replied on Sun, Dec 6 2015 12:21 AM
How about Brionvega...saw this recently at a store and iconic design...
http://www.brionvegaradio.it
BV11-55, BS9000, BL1, BL19, Transmitter 1, Beo4, Beocom 6000, BeoTalk1 200, Sennheiser HD600, McIntosh MHA100
rxcohen
New York
Posts 201
rxcohen replied on Sun, Dec 6 2015 12:30 AM
Also look at tivoli audio...looks quite nice though probably made in china these days...(like everything else)
TWG
Posts 1,672
TWG replied on Sun, Dec 6 2015 7:20 AM
I can not recommend Tivoli audio... my wife bought one for the kitchen after the 2nd Beosound 3 died and the quality (it's just a radio) is not very good. When you switch e.g. from FM to AUX you hear loud noises from the speaker... unbelievable for a nowadays product.
Greg
Posts 24
Greg replied on Sun, Dec 6 2015 5:00 PM
Thanks for these suggestions; I don't think either Tivoli or Brionvega are quite the quality of things I'm looking for - both a bit plastic looking. Not sure how the Beotime alarm works, though it looks beautiful, and in any case we have no other B&O stuff in the bedroom...  I guess I have to give up for now and buy some cheap plastic thing!  G.
Greg
Posts 24
TWG
Posts 1,672
TWG replied on Sun, Dec 6 2015 5:17 PM
The Beotime is made out of aluminium and you can use it without any Bang & Olufsen equipment!
You can e.g. use devices like the Lightmanager from jbmedia (even the old ones) to switch on the lights with compatible sockets when the alarm starts.
CB
> You are Here <
Posts 1,762
CB replied on Sun, Dec 6 2015 9:18 PM
Have a look at Soundfreaq SunRise alarm clock...
http://www.soundfreaq.com/collections/sound-rise
tournedos
Finland
Posts 7,357
I just spotted this wake-up light in local commercials Big Smile
I can also recommend the flute-model Beotime. But be sure to replace the batteries in time if you rely on it actually waking you up.
--mika
stefan
200 miles from Struer
Posts 2,920
stefan replied on Mon, Dec 7 2015 9:07 PM
If you have an iphone just get the old beoplayer app. It can work as an alarm clock with the same chimey sound we all love from the beotime.
You can also select a song or a radio station to wake you, and it does simply cost ... Nothing.
Stefan
Millemissen
Flensborg, Denmark
Posts 14,680
You can't get the 'old beoplayer' app anymore.
So - unless you already had gotten it at some point earlier - you unfortunately can't benefit from that little gem anymore.
Page 1 of 1 (13 items) | RSS
