Is it possible to upload current config on my Beo5 to new laptop? Any ideas how?
Thanks.
Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Pro, iPhone 6S, B&O Play H3, Beolit 12, Form 2, A8 Headphones, B&O Play A1, B&O Essence
You CANNOT download from your Beo5 to the Configuration Tool.
If someone else produced your configuration and uploaded it to your Beo5, then you will need to get a copy of that configuration file, otherwise you will be forced to recreate the configuration from scratch.
Regards Keith....
If, however you produced the configuration on another PC and you now have a new PC, then you can transfer the "Configuration.xml" from the clients sub-directory to the same location on your new PC
In which folder does the config file have to go?
