Hello,
I see the Moment is now called Gen 2 when I ask for a quote from my dealer. Does anyone know what the difference is between it and Gen 1? I can't find any info on the B&O site regarding it either.
Thanks!
BeoLab 18's. Beolab 3's. A8. A9. A2. H7.
I am not aware of any Gen 2 of the Moment.
However your dealer could mean a BS Moment after 'multiroom' became possible.
I do really hope, this was a bad joke, a hoax or a misunderstanding from your dealer. Offering a better version of the Moment just months after the release, without solving all issues on the first generation would be a kick against all customers, who just bought the device. Most of them still believe, that B&O will fix all toothing issues for good and therefore they waited patiently without returning their devices in the first place. I can not imagine, that B&O would do this.
Are you sure he doesn't meant the Essence Mk2?
Does someone know if there will be an update with the "motion detector" like it is said in the BS Moment introduction video :
"The perfect match, (...) lights up when i'm around..."
https://www.youtube.com/watch?v=sWkAbKUjMnE
I think you are right. He must have meant the Essence Mk2.
