Beolab Penta light stays green
This post has 7 Replies | 0 Followers
Rob - Danish AV
Melbourne
Posts 376
Rob - Danish AV Posted: Sun, Dec 6 2015 9:53 PM
Hi all
Ive recently had the drivers replaced on my Beolab Penta Mk2, and ever since the green light has stayed on, they work great, look fantastic and operate fine in every other way, They just don't go to standby, i have tried all switches, turning off & on again and its the same behavior with different sources connected
I had a read online and couldn't find anything to help, so if someone here has a suggestion that would be great :)
Rob - Danish AV
Melbourne
Posts 376
any suggestions?
Im also looking for part number 9033 which is the little toggle release catch for the front flap is anyone has one :)
Evan
USA
Posts 3,621
Evan replied on Thu, Dec 10 2015 1:56 AM
I have the EXACT same problem. If you find a fix - please let me know!! Big Smile
If I find out before you, I will report here and/or my PentaLab thread.
Beo4 'til I die!
pepps
Kent, UK
Posts 116
pepps replied on Thu, Dec 10 2015 2:13 PM
Rob.B:
any suggestions?
Is this the clip you're after?
http://www.ebay.co.uk/itm/B-O-BANG-AND-OLUFSEN-COMPATIBLE-PENTA-BASE-CLIPS-REF-PENTA-/261745378918
As for the LED issue I've no idea.
Julian
marc
s. wales uk
Posts 184
marc replied on Thu, Dec 10 2015 2:56 PM
Hi
i also have a pair of penta 2s which have same fault, the drivers have not been done yet, but as you say with yours mine are also working fine apart form whats been mentioned, with what looks like a common fault i think we will get some good info soon from this site.
marc
Lee
Newcastle upon Tyne UK
Posts 734
Lee replied on Thu, Dec 10 2015 7:12 PM
This has been fixed in the past by changing TR BC337-40
marc
s. wales uk
Posts 184
marc replied on Thu, Dec 10 2015 8:23 PM
Hi Lee
Would this be for both speakers, how does this fault happen to both speakers at the same time
marc
Lee
Posts 734
Lee replied on Thu, Dec 10 2015 8:36 PM
Hi Marc,
Unfortunately I'm not sure. It's just something I read on an old post.
Lee
Page 1 of 1 (8 items) | RSS
DigiCert Secured Site Seal
