BG6000 Type5502 Tonearm cable connections hum
ALF
AUS
Posts 1,015
Silver Member
ALF Posted: Mon, Dec 7 2015 10:36 AM
greetings all,
finally I got the mechanics working - now have to tackle a hum through the tone arm-cable connection !
I am working on a BG6000 that came without the CD4-preamp board - also missing is the mute circuit !!
there are too many wires on the connector, which was originally wired to that missing board #6,
meaning I have to connect directly to the outgoing 5-pin DIN plug cable.
looking at he circuit diagram I should only connect the wires for FL & FR, common ground and chassis
meaning PIN# 1, 9, 7 and 5  as all other wires serve no purpose in this case ?!
could someone confirm that or correct me.
I opened the DIN plug to make sure none of the wires have come loose as a possible cause of the hum- all checked out  fine !
perhaps there is the possibilty of a faulty  cartridge ??
thanks for your support
ALF
ALF
AUS
Posts 1,015
Silver Member
ALF replied on Mon, Dec 7 2015 1:36 PM
Problem solved. Devil
Missing internal chassis-earth wire connection !!!
Thanks to all interested followers :-)
ALF
Lee
Newcastle upon Tyne UK
Posts 734
Lee replied on Mon, Dec 7 2015 11:35 PM
Well done Alf!!!
Another one saved :-)
Page 1 of 1 (3 items) | RSS
