Can I use beolab transmitter 1 in a dobly atmos set-up?
themihai
Posts 32
themihai Posted: Wed, Dec 9 2015 4:08 PM
I'm looking to set-up a wireless home theater in Dobly Atmos configuration. However it seems the transmitter supports at most 7.1 so I guess I should look for another vendor. Can someone confirm me this is the case?
BeoMegaMan
Posts 601
This is true. However you could always add more Transmitter 1's to the setup.
Ah, you know... A little B&O here, a little there
rfrichg
Posts 36
rfrichg replied on Thu, Dec 10 2015 4:28 AM
The Beolab transmitter support 8 channel so you choice if it has to 7.1 or 8.0 or 5.3 or what you want
rfrichg
Posts 36
themihai
Posts 32
themihai replied on Thu, Dec 10 2015 12:42 PM
How can I do that? I couldn't find anything in the manual to suggest that multiple transmitters can be paired
themihai
Posts 32
themihai replied on Thu, Dec 10 2015 12:44 PM
At os requires 7.1.4  so I think I'm 4 channels short
Emil Jensen
Denmark
Posts 766
Halle themihai,
As I assume you will use a surround processor with atmos pre-out, the possibility of using two transmitter should not be a problem at all.
The only reason it have not been stated is maybe because there is very few people who have this option available as the cost will be high and the room required will have to be large.
I drive two Beolab 17 and a 19 with an transmitter 1, and the transmitter does not detect the speaker as something special, only the surround processor does that, so no problem.
themihai
Posts 32
themihai replied on Fri, Jan 22 2016 2:43 PM
Seems are right! If you have enough Beolab T1s  in theory you can each up to 72 sound channels(each country seems to have about 9 channels available on the 5Ghz band).
Page 1 of 1 (8 items) | RSS
