Check the relay for playback/record (tapehead) switching.
Put an ohmmeter to its contacts. Tap it with a pencil or give it a shot of contact cleaner.If in doubt replace it. It's often found bad. A 5V type will be fine.The same goes for the two black Roederstein capacitors with the green lettering right next to it. 2x 470uF if I remember correctly.And thanks.
Good job!Haopy I could help.
And thanks for posting the positive result, often people forget that.
