Powerlink
This post has 8 Replies | 2 Followers
Seanie_230
UK
Posts 2,278
Seanie_230 Posted: Wed, Jun 27 2012 10:16 AM
Hello All
I know powerlink has a preamped line out in the cable for left and right
i also know that there is a pin for speaker on.
Does anyone know what voltage is used for the on signal?
im hopnig 12 volt so it can triggar a seperate amp to switch on.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
stefan
200 miles from Struer
Posts 2,920
stefan replied on Wed, Jun 27 2012 11:21 AM
It`s only 4-5 volt on PIN 4.
Stefan
Desmo
Posts 27
Desmo replied on Wed, Jun 27 2012 11:09 PM
It's 5 V ideed.
But you can covert it very easy from 12v to 5v with a resistance and a zener diode.
For more information look here: http://www.hifi4all.dk/forum/forum_posts.asp?TID=23818
This worked perfectly for me.
Seanie_230
UK
Posts 2,278
Hay sorry other way round I want to use the powerlink 5v to triggar a 12 v trigger on a amp
Would this work is .83mamp enough current?
http://uk.farnell.com/murata-power-solutions/mer1s0512sc/converter-dc-dc-1w-5v-to-12v/dp/1818323
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Step1
Manchester, UK
Posts 1,268
Step1 replied on Tue, Jul 3 2012 10:13 AM
Persoanally I would not recomend the dc convertor, the powerlink signal will not be designed to power loads, which is what this will present itself as.
What I would do is build a little box with a switched 12v signal coming from a separate power supply. You could make it nice n neat and it would still be very simple!
Seanie_230:
Olly
tournedos
Finland
Posts 7,357
tournedos replied on Tue, Jul 3 2012 12:22 PM
Step1:
Perhaps more to the point, I don't think it would even work. For example in 9500, the Powerlink pin 4 signal comes from a CMOS port pin through a 1K resistor. If you load it by for example 2 mA only, the output voltage will have dropped below 3 volts. I'm sure it can't even supply enough current for the converter to start up, let alone produce any useable output.
--mika
Seanie_230
UK
Posts 2,278
Hi there
so i need to build a small peice of electronics that will receive a very low signal and then use a external power supply to switch a 12v feed on.
this should not be to difficult, thanks all
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
tournedos
Finland
Posts 7,357
Seanie_230:
Yes, at the minimum it could be a single transistor (and a base resistor and a protection diode) that would be enough to drive a relay, for example. There's probably an example somewhere in the archives already.
--mika
liberal
Posts 43
liberal replied on Wed, Jul 4 2012 4:03 PM
i have been using one of these for s few years now to control a 12v trigger signal (from a 12v plug top  power supply)  to power amplifiers  from the 5v powerlink output  of my Beosound 9000.
http://www.quasarelectronics.com/smart-kit/1168-logic-or-led-activated-relay-board.htm
Super Best
Paul
Page 1 of 1 (9 items) | RSS
