hi,
I tried to use the ATSC tunner on my Beosystem 3 and the TV does not pick any channel( ATSC is ON).
I installes the antenna on the ANT2 and ANT3 jack and the same result....no channels!
The antenna is working well with an LG TV.......
Is there a trick to make it work?
Thanks in advance for any help!!!!
Good evening,
I have a Beovision 7-40 Mk3 which is Beosystem 3 based. There are two antenna connections, and one is marked ATSC/Digital. Use this one. With a cheap rabbit ears antenna, I can receive all Montreal TV channels and, on some days, some US channels. So, it should work. Ensure that the connection is good.
Use DTV on the Beo4 remote and ensure that it was not disabled and reassigned to another input in the menus.
Good luck,
Jean
jvezina: Good evening, I have a Beovision 7-40 Mk3 which is Beosystem 3 based. There are two antenna connections, and one is marked ATSC/Digital. Use this one. With a cheap rabbit ears antenna, I can receive all Montreal TV channels and, on some days, some US channels. So, it should work. Ensure that the connection is good. Use DTV on the Beo4 remote and ensure that it was not disabled and reassigned to another input in the menus. Good luck, Jean
Thanks jean for your help.
Unfortunately there is no ATSC/Digital mark on the Beosystem 3. Only Antenna 1, 2 and 3.
1 slot is disabled( plastic cover).
ATSC is ON on the TV Menu.
I do not have any DTV on the remote, only SAT. When I press SAT, screen is green.
Where is located the ATSC/Digital on your Beosystem 3. It is the middle connection?
Good morning,
The ATSC tuner antenna input should be antenna 2 (see diagram)
