Quick question.
I have put my Beosystem 3500 with Beolab 8000's connected in the same room as my Beovision 11 but not connected together.
I've decided I don't want to use the Beovision as an audio source. Only thing is that now I have the Beo4 and the BeoRemote One in the same room and there is a big confusion. I have a Beo5 but I could never get the configure tool to connect. So ultimately I would like to use the BeoRemote one to control everything if that is possible. I have a Beolink converter type 1611 if that would be of any use?
Thanks!
This post might help
http://archivedforum2.beoworld.org/forums/t/17659.aspx
Thanks MM. All sorted as that post reminded me to check which option it was.
