BeoLab 14 5.2+ or 7.2
This post has 6 Replies | 0 Followers
Mark-N
Maryland, USA
Posts 320
Mark-N Posted: Mon, Dec 14 2015 9:16 PM
I have a BeoLab 14 5.1 system in my living room which I like alot!  I'm not sure why I did this but an opportunity came for me to get a BeoLab 14 2.1 system and in a weak moment I purchased it.  I was wondering how the system would sound with 2 subwoofers, one on each side of the room, next to the front speakers.  These would be connected to a BeoSystem 4.  Now my dilemma is what to do with the other two speakers.  Option 1 would be to get ceiling mounts and place them as side speakers at the couch.  Option 2 would be to use the ceiling mounts and place them above the front speakers which are on floor stands and use them as fronts.  The 7.2 setup would work well for movies, and I am thinking that the expanded 5.2 would work well for music which would be very nice if it does work well.  Does anyone have any thoughts?
mjmedlo
Posts 922
mjmedlo replied on Mon, Dec 14 2015 9:59 PM
How would you connect it?
Mark-N
Maryland, USA
Posts 320
Mark-N replied on Mon, Dec 14 2015 10:07 PM
The BeoSystem 4 has 6 PL connections.  3 are used for my original BeoLab 14.  If I use the 2nd BeoLab 14 as fronts, I am guessing I can get away with one additional PL cable as it shows in the manual.  If I use side speakers then I would need 2 PL connections.
Millemissen
Flensborg, Denmark
Posts 14,680
Hi Mark-N,
I suppose, that you already have consulted the 'Technical Sound Guide' on the B&O website?
Mark-N
Maryland, USA
Posts 320
Mark-N replied on Mon, Dec 14 2015 10:49 PM
Hi MM,
Actually, I wasn't aware of the guide.  I'll have to find it.
Mark
Mark-N
Maryland, USA
Posts 320
Mark-N replied on Mon, Dec 14 2015 11:34 PM
Thanks for the link!  I had trouble finding it because I thought it was a generic document and tried a google search on it.  I found one of them, although it wasn't for the BeoSound 4.
Page 1 of 1 (7 items) | RSS
