Brought a BeoVision 11 about a month ago and forgot to ask what the mains cable length was in the UK and really hope it's long enough when they come to install next week and starting to worry a little and was wondering if anyone could put my mind at rest?
Seems like I'm asking a lot for it to be 5 meters long but was hoping with it being B&O that they carry cables that long for custom installations!
Thank you in advance
Sitting Room BeoVision 11-46 Motorised Floor Stand - BeoLab 11 - BeoRemote One - BeoCom 5 - Beogram 3000 (Type 5228) - Cambridge Audio Alva Solo Preamp - Oppo BDP93EU - Apple TV 4K (2gen) - 3D Glasses Kitchen BeoSound 1 - BeoRemote Halo - BeoCom 6000 mk2 Bedroom BeoSound 35 - BeoRemote One - BeoTime Bathroom BeoSound Level Utility Room BeoSound Level Home Office BeoSound 2 - BeoRemote Halo - BeoCom 6000 Mk2 Home Gym BeoLab 28 On The Go H95 - H7 - E8 3.0 - H5 - A2
Best to check with your dealer / installer in advance and that way they can ensure they have a suitable cable on board. Alternatively you could order one yourself (13A plug to C7) from CPC for example - if you do this you may find it is as cheap to order two as they add a £2.50 handling charge for orders under £5.00.
Kind regards,
Thank you Martin for your answer :-) I've emailed my dealer this morning and no reply yet but they are extremely busy at the moment and the last I heard even the manager is having to go out on installations but if they don't I'll take your other advice and order a cable, would have liked a answer from the dealer sooner has its being fitted on Tuesday 22nd December and its soon the weekend
I don't know if you are still looking for mains cables? If so just scroll to the bottom of your screen and order direct from Steve @ Sounds Heavenly. He can make you custom lengths if needed. He made me extra long mains for my 12-3's ( rear channel surrounds). He's quick and pricing is great
