Essence with HDR2 IR module?
leosgonewild
Helsinki, Finland
Posts 2,373
leosgonewild Posted: Fri, Dec 18 2015 4:20 PM
I am working on mounting my Essence and ICEpower 250asx2 into a HDR2 casing.
There is an IR receiver in the front plate of the HDR2. I guess it should be possible to connect it to the Essence so I can use a Beo4 with it.
Does anyone know how I can wire it? Here is pictures:
leosgonewild
Helsinki, Finland
Posts 2,373
Come to think about it, it's not an IR receiver. It's controlled from a BV Sad
Millemissen
Flensborg, Denmark
Posts 14,680
You maybe could fit in an original Essence ir-eye somehow?
leosgonewild
Helsinki, Finland
Posts 2,373
Yes, it should work. Only problem is that one mine the screws doesn't unscrew Sad
Millemissen
Flensborg, Denmark
Posts 14,680
Leo..., not the 'wheely', but the ir-eye (the new round one, that is also used for the NL/ML converter).
leosgonewild
Helsinki, Finland
Posts 2,373
Mille.. The screws in the inside of my IR-eye are broken Wink
Millemissen
Flensborg, Denmark
Posts 14,680
I see 🙀
Page 1 of 1 (7 items) | RSS
