Besound 3000 CD
Beosystem 7000 CD
Essence mkII
all at the same time
Eclipse 65V1-32Beosound M5Essence MK2BLI
Seanie_230:Hi there How did you manage this? Do you have multiple converters? BLGW - Rekindling the love of ML
Seanie_230:Hi there Thank you. So I assume you have one convertor per device and the ML cable is only connected between the two of them not all ML devises connected together.
Thank you.
Seanie, your right one BS per BLC. The ML systems are not connected
Razlaw:What can you do with the BS3000 from the app?
play next/previous
My hat is off to Carolpa 👍
Bravo!
N.B. It would be nice (and helpfull), if you could post a 'drawing' of your setup.
Things like this really proves the worth of B&O/NL - those, who claims, that all you need for 'multiroom' is a couple of ChromecastAudio's, should read this post.
Millemissen:My hat is off to Carolpa 👍 Bravo! N.B. It would be nice (and helpfull), if you could post a 'drawing' of your setup. Things like this really proves the worth of B&O/NL - those, who claims, that all you need for 'multiroom' is a couple of ChromecastAudio's, should read this post. MM There is a tv - and there is a BV.
Millemissen:Things like this really proves the worth of B&O/NL
I agree.
I don't own any NL products yet (except for a NL/ML converter, which I bought because I had the opportunity to buy it used at a very good price and because I'm intending to buy an essence very soon), but having spent most of the afternoon in my local store yesterday listening to the BL90s and at the same time transferring sources between lots of different NL devices I feel like I have a much better feel for what is possible and for how well it all integrates.
NL really does open up a whole new world of possibilities, as Carolpa's setup demonstrates.
Martin.
Razlaw:So basically full control of the 3000? Everything except volume?
That is cool news! :-) Is it a Beosound 3000 MK1 or MK2 or doesn't it matter?Is the Beosystem 7000 controllable in the same way as the Beosound 3000? Why doesn't B&O do marketing for that???
TWG:Is it a Beosound 3000 MK1 or MK2 or doesn't it matter?
TWG:Is the Beosystem 7000 controllable in the same way as the Beosound 3000?
That are really great news! Who could imagine that you can control an >20year old system with todays software? VERY nice from B&O!I guess this will work with Beosound 9000, Beocenter 2 etc., too?!
TWG: That are really great news! Who could imagine that you can control an >20year old system with todays software? VERY nice from B&O!I guess this will work with Beosound 9000, Beocenter 2 etc., too?!
Beosound 5?
Razlaw:Beosound 5?
Yep, that too. There shouldn't be any issues with connecting a BM5/BS5 to a NL network using the NL/ML converter (indeed it is one of the examples shown in the handbook)
Kind regards,
mjmedlo:Carolpa Do you have the nl converters connected directly to each device? And then on to the network? Or are they connected in a rack room somewhere? Just curious about how you've done this.
Yes it works. 1984 Beogram 6006 + 1987 Beocenter 9000 feel fine in NL setup.
Yann.
Living Room BV Eclipse - BS Core - BL5 - BL8000 - LC2 x2 - Beo6
Lounge Beolink Passive - Cabasse Clipper - Beo4 Kitchen BL3500 - Beolink 1000
Bedroom BV9 - BL6000 (Thks Botty) - Beotime - LC2 - Beo5
Garden Lounge BC9000 - BG 6006 - BL4500 (Thks Botty) - Playmaker - Beolink 1000
Study BS1 - ML/NL Converter - BL2500 - Beo4 - Form 2 (Tks Botty) - Beoplay P2
riverstyx:Yep, that too. There shouldn't be any issues with connecting a BM5/BS5 to a NL network using the NL/ML converter (indeed it is one of the examples shown in the handbook) Kind regards, Martin.
Razlaw:But it would still just give basic control of the BS5, no ability to select music, correct?
As I understand correctly: You'll need one NL/ML-Converter per device? If you have e.g 5 Beosounds/Beosystems in your setup you'll need 5 NL/ML converters to control them via software and be shown in the software? I thought you can configure multiple ML-sources in that converter or am I mixing up the devices!? :-)
TWG: As I understand correctly: You'll need one NL/ML-Converter per device? If you have e.g 5 Beosounds/Beosystems in your setup you'll need 5 NL/ML converters to control them via software and be shown in the software? I thought you can configure multiple ML-sources in that converter or am I mixing up the devices!? :-)
to control them all with a remote would be impossible.
Why people want a NL/ML per device is to be able to maneuver them with the app. If you just want your link system to be extended to include NL products, you do not need multiple NL/ML converters.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
ok, thank you.
