TV picture 'snow' - any suggests on what's causing it?
This post has 5 Replies | 2 Followers
Coolhurst
Posts 10
Coolhurst Posted: Tue, Dec 22 2015 9:58 AM
I recently purchased a Beo7-32 mk 3. Without any way of testing it from the seller I took a bit of a gamble. Having now hooked it up to a Bush Freesat HD box (via Dvi and scart for audio) I've noticed very fine (small) fleckles appearing randomly on screen. They're very small, flash on rapidly across the screen and so small that they aren't detectable at viewing distance. Nevertheless I'd like to understand what's causing them to appear.
Could it be Leads? TV screen issue? Freesat box?
BTW, these 'flecks' do not appear when I play a Dvd.
Has anyone experienced this kind of thing before and therefore suggest a solution? Failing that all suggestions on likely cause are appreciated and most welcome.
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Tue, Dec 22 2015 11:04 AM
Coolhurst:
Hi
It sounds like what is called "sparkles" and is usually caused by either very long or poor quality HDMI / DVI leads or adaptors.
Kind Regards,
Martin.
Millemissen
Flensborg, Denmark
Posts 14,680
I'd say so too.
Try another (better) cable.
Coolhurst
Posts 10
Coolhurst replied on Tue, Dec 22 2015 3:20 PM
I appreciate the replies and suspect you are both right - the current cable is an cheapie ebay special!
I'll go up-market and see what happens. Will let you know how I get on
Coolhurst
Posts 10
Coolhurst replied on Sun, Jan 17 2016 9:12 AM
Thanks both, you were spot-on with your suggestion that it was the lead at fault. What a difference a few more £££ spent makes. All now sorted.
Whilst I'm on, do you know what constitutes high usage on a bv7 in terms of days. Mine shows video days at 685 and 'on' at 440. And that's high worth getting a service? Picture is okay, not brilliant.
cheers
Andrew
Frinton, UK
Posts 917
Andrew replied on Sun, Jan 17 2016 12:51 PM
I think that's relatively ok and not high.
I found that I was disappointed with the picture on all the B&O tv sets I have BV8 and 2 x BV6 - if you go into the service menu you can alter the contract, colour, brightness above those that are on the user menu - this made a massive difference to mine anyway. Copies of the right manual are available on this site but you need a membership to access them - hope this helps.
Page 1 of 1 (6 items) | RSS
