Razlaw:If a Beosound 3000 and a Beosound 5 are connected by MasterLink and are in two different rooms, And if an Essence is connected to the Aux in of the Beosound 5 using the Behringer device, Will activating A.Aux on the Beosound 3000 allow it to access the Essence just as activating A Aux on the Beosound 5 would? Or would it look for something connected to A Aux on the Beosound 3000?
What if BS3000 (option 6; a later version of the BS3000) and BS5 (option 0, 1 or 2) in two different rooms;
BS5-Behringer reacts on A.Aux
BS3000 reacts on L.A-AUX (presumably you need a BL1000) ???
Yes, should work.
Also with Beo5/6, ML/BLGW.
Stefan
stefan: Yes, should work. Also with Beo5/6, ML/BLGW. Stefan
Just another idea: Connect the Essence to the BS3000 (option 2) A.AUX. Place the BS5 in de mode where it isn't a AMaster.
Wouldn't this work?
I connected a source to the Beosound 3000 Aux In. Option 0 on Beosound 3000. Audio Master off on the Beosound 5.
Pressing A. Aux on the Beo 4 in the two other rooms of the house, the room where the Beosound 5 is located, and another room, activates the source connected to the Beosound 3000.
deleted
