Greeings all :-)
Don't want to add to any confusion but I was under the impression all BG4xxx models
Come with a record cleaning function by just keeping the '33'key depressed or am I
mis-informed ?
Reason for asking is, I have two BG4002 models and none seem to do that ??
Which are the critical parts involved with the function that could possibly be faulty ??
Could someone enlighten me here ??
Just the right sort of job over the christmas break :-)
Cheers, ALF
Thank you Rich,
That is how I remember the record-cleaning function and doubt very much it would be
Different with different types of the BG4xxx series ?!
However, my initial question was about thoses crucial components involved to make that happen ??
The cleaning function does not work on some of my tables which indicates to me there's
A fault somewhere !??
Cheers ALF
hi lee,
well, that seems correct on the BG4002 but the BG4000 and BG6000 definitely have record cleaning functions without that "start and lift-up business" - I can not comment on the BG4004 as the owners manual is not available ?!
so, we are both correct , but with some BG4002 types is seems an option !!
sorry, I have two of those tables as well as the quadrophonic BG6000 and BG4000.
lucky me :-))
ALF
