Can anyone please remind me what the right way to cable my old Beolink converter to a BM7000?
I vaguely recall having two cables attached. Powerlink and/or Line in/out?
Thanks!
Michael: Can anyone please remind me what the right way to cable my old Beolink converter to a BM7000? I vaguely recall having two cables attached. Powerlink and/or Line in/out? Thanks!
PL cable straight forward
Datalink cable from a.aux link to tv
double post
Thanks.
One last thing. In the absence of the Data Link cable is there any downside ( signal qiuality wise) to using, instead, an old power link cable by simply removing the center pin?
Michael:Thanks. One last thing. In the absence of the Data Link cable is there any downside ( signal qiuality wise) to using, instead, an old power link cable by simply removing the center pin?
with fully wired PL this should work
note: connect everything else before connecting the T1611 to the mains
