Found that pic on the net.
The game is to try to change a cd without dropping the upside down Beosound 9000 on the floor .
Gregory
BeoGreg:Found that pic on the net. The game is to try to change a cd without dropping the upside down Beosound 9000 on the floor . Gregory Since 1995 : too much to re-write on the new site. Various Beosounds, Beovisions, Beolabs, Beocords, Beocoms...
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
Michael: Actually it is designed to stand like this with the right stand :) but it looks interesting right? You can also mount it upside down (with the glass upwards) on the wall. That must be the hardest position to change CDs in.
There is indeed a table stand - but never with the 9000 in this position! It sits with the grey ribbed section at the bottom...
You can mount it like this with the wall bracket though.
Lee
Ah, apologies :)
