Bemomaster 5500 shuts down after a few minutes
Travelfreak
Posts 5
Travelfreak Posted: Sun, Dec 27 2015 6:44 PM
I have a used Beomaster 5500 and works fine until the unit warms up a bit and shuts down no matter if you are using FM, cassette, CD, or phono.  Amp will power back up immediately however the shut down comes quicker with each successive power cycle.  I have read through the forums and found a few notes about trimmers perhaps needing replacement.  I am electrical proficient but need instructions and help from a pro if possible.
Travelfreak
Posts 5
Nevermind I fixed it myself. :-)
Travelfreak
Posts 5
Thanks for the information
Michael
Oklahoma
Posts 19
Michael replied on Mon, Dec 28 2015 9:37 PM
No details?
Travelfreak
Posts 5
I used the schematic to locate the two output trim pots and gave both left and right a half turn back and forth to renew the internal resistant setting location and returned to initial settings.  When I tested it afterwards, the problem solved.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Mon, Dec 28 2015 10:23 PM
Replace the trimmers, - they will fail again if not.  They are cheap and easily available.
And you definitely need to put a multimeter on the emitter resistors and set the idle currents per the manual.
Once you do, you will see, that the adjustments are quite sensitive, even very small movements will make a huge difference and you cannot
just "put them back where they were".
Too high idle and the output stage will overheat, too low and you will overload the tweeters even at lower volumes because of ultra high-pitched
harmonics from crossover distortion.
Keep in mind that this is a Class B amplifier.
Travelfreak
Posts 5
Martin,
Thanks for the info and at this point I am selling the system so thanks anyways.
Richard
Toledo, Ohio USA
Posts 17
Silver Member
Richard replied on Sun, Jul 23 2017 2:48 AM
I have the exact same problem. Entire system has been stored in a closet for years, likely due to this issue. Turntable works great but it as well as the CD player & tape deck all come on & system shuts down. My daughter thought she could smell something electrical. Overheating?
DMacri
United States
Posts 881
DMacri replied on Thu, Jul 27 2017 6:46 PM
Could very well be the case. Silver members can download the service manuals and Martin (Dillen) can provide the needed parts and instructions to replace the trimmers, if you're handy with a soldering iron. If so, you might as well look to replace the capacitors too, since they don't age particularly well. Martin can provide those, too. Good luck!
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
Page 1 of 1 (9 items) | RSS
