essence remote additional programming modes
This post has 24 Replies | 3 Followers
Michael
Atlanta
Posts 98
Michael Posted: Wed, Dec 30 2015 7:55 PM
I had a pleasant surprise when I discovered that the Essence Remote has several more programing modes then the 8 mentioned in the documentation.  It appears to have 12 (0-11) before it cycles around to the first one again.   Mode "8" is an IR mode that cues the TV/Aux source by default from my BM7000.
I can't figure out the others but there is atleast one additional IR mode.
Anyone know what the others may be for?
leosgonewild
Helsinki, Finland
Posts 2,373
4real?? I thought it was impossible to have it send an aux command. I never noticed mine having any extra modes. A video would be nice 😀 and serial/model number.
Michael
Atlanta
Posts 98
Michael replied on Wed, Dec 30 2015 10:27 PM
Well I can't confirm that it's actually sending "Aux" (until I get out my old Lintronic box) as it may just be the reaction my BM7000 is having to any "other" source command that it thinks it can fulfill through the Aux input.
Mine is SN:24025412 made 6/2015 and sold with the essence mkII.  It did not have a firmware indicator that I could tell.
Here are the modes 0-7 and 8-11 with the 4 corresponding program LED indicators ( "0"= LED on  "_"= LED off)  including the new ones I've found:
MODE0   Bluetooth - paired
BeoSound Essence
0___
MODE1   BeoRemote One IR (BeoSound)
A sound system intended for use with BeoRemote One
_0__
MODE2   Beo4 IR (RADIO)
A sound system intended for use with Beo4
__0_
MODE3   ‘Light’ mode
___0
MODE4   Beo4 IR (BeoPlay)
A sound system intended for use with Beo4 (BeoPlay)
_00_
MODE5   BeoRemote One IR (BeoSound (2))
A second sound system intended for use with BeoRemote One
_0_0
MODE6   BeoRemote One IR (BeoSound (3) )
A third sound system intended for use with BeoRemote One
__00
MODE7   BeoRemote One IR (BeoVision)
_000
MODE8  Infrared?  Possibly Aux or tv/Video
000_
MODE9  Infrared?
00_0
MODE10  ?
0_00
MODE11  ?
0000
Millemissen
Flensborg, Denmark
Posts 14,680
Interesting stuff - can anyone else confirm that?
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Wed, Dec 30 2015 10:45 PM
Additional modes allowing for both Bluetooth and IR signals valid for Wall edition from serial number 24575625 and Table edition from serial number 24025292
        LED  A    B    C    D
8 Beo4 IR (BeoPlay) In combination with Bluetooth A sound system intended for use with Beo4 (BeoPlay)                                              On  On  On  Off
9 BeoRemote One IR (BeoSound (2)) In combination with Bluetooth A second sound system intended for use with BeoRemote One     On On Off   On
10 BeoRemote One IR (BeoSound (3)) In combination with Bluetooth A third sound system intended for use with BeoRemote One       On  Off  On   On
11 BeoRemote One IR (BeoVision) In combination with Bluetooth A television intended for use with BeoRemote One                             On  On  On   On
Regards
Opman
Millemissen
Flensborg, Denmark
Posts 14,680
Could you - or anyone else - present some user cases for these options?
leosgonewild
Helsinki, Finland
Posts 2,373
The Bluetooth + IR aux could start playing from a Essence that is connected to a BS's aux.
Meaning it will both turn on the BS (choosing a.aux) and start playing Spotify/Deezer from the Essence. And it would still be possible to skip tracks with the wheel.
TWG
Posts 1,672
TWG replied on Sat, Jan 2 2016 8:30 PM
1st: Happy new year! :-)
2nd: A very positive and welcome finding and ideal for use cases like the one Leo mentioned! :-)
Thank you for that.
I have two essence remotes and they both miss the additional modes! :-(
Which means for special setups only the new generation can be used.
The table mounted version's serial number starts with 238... on the wall mounted version I can't see any serial number.
How are the newer versions identified?
Can the older remotes simply be updated by B&O? (I remember somebody mentioned the original manufacturer of these remotes here in our forum...)
And why oh why is Bang & Olufsens documentation and information behaviour  always so infamous??
Millemissen
Flensborg, Denmark
Posts 14,680
leosgonewild:
Thanks!
That's cool.
Millemissen
Flensborg, Denmark
Posts 14,680
leosgonewild:
Thanks!
That's cool.
CB
> You are Here <
Posts 1,762
CB replied on Sat, Jan 2 2016 11:04 PM
TWG:
There should be a white rectangular sticker (not sticked !) with the serial number in the box...
leosgonewild
Helsinki, Finland
Posts 2,373
If you want to upgrade, I would be interested in your old ones.
Millemissen
Flensborg, Denmark
Posts 14,680
Any more news about these new ir-modes?
Has any one tried them out in real life?
Still no further information about these in the B&O FAQ's :-(
Even my dealer did not not even know about these.
petrosbeli
Posts 64
Those new modes allow the Essence Remote to work at the same time with IR and Bluetooth.
They are used in the case you have plugged an Essence Box to the line-in/AUX of an older BeoSound/BeoMaster product. Those new modes would send AUX & volume commands (to the old BeoSound/BeoMaster) via IR, but at the same time prev/next/change source will go to the Essence Box via Bluetooth.
Millemissen
Flensborg, Denmark
Posts 14,680
Thanks!
Bad luck for me ;-(
My Essence is plugged in to the A.Tape input of my old audiomaster, so that won't work.
Anyway - B&O and the dealers really ought to make this public.
Looking forward to see, which possibilities the new BeoRemote One/BT will bring - maybe there
will be other options there.
TWG
Posts 1,672
TWG replied on Sat, Oct 1 2016 7:21 AM
Good Morning,
does anybody know how exactly to use the Bluetooth + IR mode? Do I have to pair the remote with e.g. an essence and switch the mode of the remote afterwards or how does it work?
by the way if anyone is interested: Here's how an Essence remote looks partly disassembled. I bought this table version on ebay and didn't know (the photos did NOT show the back) that the former owner had tried to "repstroy" it. I don't know if he tried to bite or burn this thing open... Sad
beojeff
USA
Posts 2,012
beojeff replied on Tue, Jun 18 2019 5:35 PM
I thought I would revive this thread to seen if anyone has had more experience with using the various Essence Remote modes. Also, it would be useful to have a better understanding of what the beoplay and beosound modes really do that make them different from the standard IR mode. The documentation available does not provide a good understanding of actually when to use the various modes. When I get a chance, I might try some modes and use my BLGW monitoring tool to see just what is sent out.
I thought of this thread because there is someone who recently posted a thread about connecting a Moment to the AUX input of his BeoSound 9000. The undocumented "extra" modes can be used to turn on the BeoSound 9000, switch it to the AUX, and control the volume while using bluetooth to turn on an Essence and control the tracks. While the Moment is not bluetooth, I wondered if the extra modes could still be useful in switching on the BeoSound 9000 and switching it to AUX - even though it would not be used to switch tracks on the Moment.
CB
> You are Here <
Posts 1,762
CB replied on Tue, Jun 18 2019 6:56 PM
The wheely can not work in both IR and BT at the same time. You’ve got to choose one or the other.
And I thought there were no more undocumented modes ?
https://archivedforum2.beoworld.org/forums/p/11344/134944.aspx#134944
beojeff
USA
Posts 2,012
beojeff replied on Tue, Jun 18 2019 7:01 PM
CB:
That's true with the documented modes. However, there are extra undocumented modes that are used for the combination of using an Essence or Core with the AUX input of an IR BeoSound (see earlier in this thread). It sets the BeoSound via IR to AUX and controls the volume of the BeoSound while using bluetooth to control the Essence or Core.
CB
> You are Here <
Posts 1,762
CB replied on Tue, Jun 18 2019 7:05 PM
beojeff:
Oh, that has certainly appeared with the mk2 remote
Millemissen
Flensborg, Denmark
Posts 14,680
Thanks for reviving this old thread.
That little wheely could be more popular if we knew, what is possible with it (read: with the the newer versions).
The only exact explanation given in this thread is the one from Petrosbeli on page 1 about ir for aux plus bt for the Essence (I guess that would go for the Core as well).
Could there be more?
And how to configure these modes?
Anyone with real life experience, please chime in.
beojeff
USA
Posts 2,012
beojeff replied on Tue, Jun 18 2019 9:00 PM
Beo4 IR (RADIO) vs. Beo4 IR (PLAY) modes:
I've always been confused by what the difference is between the two Beo4 IR modes (Mode 2 and Mode 4). The guide says that both are for "a sound system intended for use with Beo4."  That description for Mode 4 then adds "(BeoPlay)" in parenthesis. The only BeoPlay music systems with IR that I can think of were the BeoPlay A9 Mk1 and the BeoPlay A8. The key mapping guide shows that a short press on the top button in Mode 4 is for "Select" and that a long press on the top button in Mode 4 is for "CD." Does "Select" perhaps toggle through sources on the BeoPlay A9 or BeoPlay A8? Having neither a BeoPlay A9 Mk1 nor a BeoPlay A8, I could not test this.
However, using Mode 4 with my BV10, I found that the short press on the top button did nothing. A long press on the top button sent the "CD" command. The benefit that I can see for Mode 4 is if you only want to use the wheely to play CD and never use the RADIO command. Which could be beneficial in that it does not have that annoying quirk of briefly laying the radio before it detects the long press to play the CD.
TWG
Posts 1,672
TWG replied on Fri, Jun 21 2019 10:23 AM
It could be the best selling remote for B&O as it does work with 3rd party manufacturer Bluetooth devices, too.
- how can you identify the MK2 variant of the Essence remote?
- is there a link mode for the MK2 remote that supports Beo 4 commands?
The MK1 has Beoremote One modes for a 2nd and 3rd system in one room but unfortunately this does not work for Beo 4 compatible products.
beojeff
USA
Posts 2,012
beojeff replied on Fri, Jun 21 2019 12:47 PM
TWG:
I agree with you that a link mode would have been useful. Also useful would have been a LIGHT mode that still uses the wheel for volume. That way, we could have programmed the buttons to trigger whatever source we would want (for example, sources other than RADIO or CD).
I always thought that offering 3 different BeoRemote One Beosound modes was excessive. How likely is it that we would have 3 such products in one room? For that matter, what audio products actually EVEN HAVE an option to use the BeoRemote One BeoSound mode -- which is different from the beo4 IR mode? My BeoSystem 4 uses the BeoRemote One Beovision mode, but as far as I know that's the only B&O product that I have that doesn't use beo4 IR mode or BT mode.
Mr 10Percent
So West, Its Now East
Posts 591
The original Essence Remote file is here https://beointegration.com/uploaded/BeoSound_Essence_Remote_IR_modes.pdf
Apologies if it has already been posted.
Page 1 of 1 (25 items) | RSS
