BeoSound 35
This post has 136 Replies | 6 Followers
Weebyx
Denmark
Posts 1,213
Weebyx replied on Thu, Jan 14 2016 11:04 AM
petrosbeli:
Yes, line-in latency can be switched off. Here is the related official information: http://bogous.custhelp.com/app/answers/detail/a_id/7383
Thanks....
Ok, so this means that if I connect the BS35 to my TV, and also add's an A6 in the bedroom, I need to switch the delay on/off onBS35, depending on if I stream (and want multiroom functionality) or watch TV ?
But does this also mean that I cannot listen to the TV sound on the A6 ? Hmm, this is getting complicated :)
/Weebyx
petrosbeli
Posts 64
petrosbeli replied on Thu, Jan 14 2016 12:43 PM
Only the line-in source is affected by this setting. That means, that if you connect a 3rd party TV and disable the latency (so you dont have lipsync issues), it is ONLY the line-in source that cannot be distributed on the multiroom. All the other sources (Deezer, TuneIn, Spotify, DLNA, etc) can still be distributed and are not affected by this setting.
So, you dont really need to toggle this setting on your daily life...
But yes, on the down side you cannot distribute sound from the 3rd party TV (via the line-in) to the other multiroom products. This is "normal" as multiroom distribution requires a "buffering", which by nature could cause a lipsync with live sources.
You would not have this issue with a Bang & Olufsen TV, as they are designed with the multiroom functionality built-in, and they can handle the picture/multiroom sync natively (but still you need a good WiFi network, to ensure that the buffering is not long)
Hiort
Sweden
Posts 2,895
Hiort replied on Mon, Jun 27 2016 12:54 PM
Can anyone tell what BS35 show on the screen when playing from eg. Tunein?
My wife is tired of blindly flipping through TuneIn stations on our Belolab 2000 in the kitchen.
CasperI
Posts 93
CasperI replied on Mon, Jun 27 2016 3:11 PM
It shows the current playing station in the middle of the display and "TuneIn" in small letters on the upper part of the display.
petrosbeli
Posts 64
Station name is in the middle, with large font.
If the station provides metadata of the currently playing song/program, it is also displayed in the bottom...
CB
> You are Here <
Posts 1,762
CB replied on Mon, Jun 27 2016 8:13 PM
Qobuzissime distinction
The page in french is here : http://www.qobuz.com/fr-fr/info/-MAGAZINE-HIFI297
The english translation is here : http://www.qobuz.com/gb-en/info/-MAGAZINE-HIFI297
paolomariano
Posts 639
I can finally use my bs35 as a clock radio!! Lets have a Party !!!Lets have a Party !!!
Seanie_230
UK
Posts 2,278
Seanie_230 replied on Tue, Jun 28 2016 10:02 PM
Hi there
How do you rate the sound from the BS35?
I hear different opinions
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Chris Hassell
London
Posts 396
paolomariano:
Yeah I have the update to my Essence too! It says you can activate timers etc. from the Beomusic app. So perhaps there's an update coming for that too. I heard Beolink and Beomusic apps were merging.
BeoVision Eclipse 55”, Beolab 18s, Beolab 19s, Beosound 1, Beoplay P2, H3, BeoRemote One IR, BeoRemote One BT, Beoplay S8, Beosound Essence MkII, BeoTime
Millemissen
Flensborg, Denmark
Posts 14,680
If timers (now) are possible with the BS35 etc, why shouldn't they be with the NL-BV's too.
Will there be an update there too?
Or will we see the timers in the coming new BV's instead?
Flere
Netherlands
Posts 345
Flere replied on Tue, Jun 28 2016 11:11 PM
Chris Hassell:
Yeah I have the update to my Essence too! It says you can activate timers etc. from the Beomusic app. So perhaps there's an update coming for that too. I heard Beolink and Beomusic apps were merging. BV11-46, Beoplay A2, H3 ANC, Beo 4, Beoplay S8, Beosound Essence MkII
Let's hope so.
In my situation the BeoSetup app is way to slow to be usable for starting stopping timers.
You should be able to start and stop the timer from the BeoMusic app.
- Flere
smile and enjoy the moment
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Wed, Jun 29 2016 5:35 PM
Flere:
Let's hope so.
- Flere
In the next update, BeoSetup is "integrated" in BeoMusic
paolomariano
Posts 639
Seanie_230:
Hi there
I hear different opinions BLGW - Rekindling the love of ML
Hi! I love its sound! It's very well balanced, present, with realtolife voices, full bodied bass, clear highs. Just what I expected. What other opinions have you received?
Joerg
Bahrain
Posts 12
Joerg replied on Fri, Dec 30 2016 7:33 AM
yes this can be disabled. Had to do so when I set up the BS35 with my LG TV through BeoHub.
CB
> You are Here <
Posts 1,762
CB replied on Fri, Dec 30 2016 10:10 AM
Wonder what the second screen (below) is for ?
I tried to tilt the BS35 back and forth to see if the display changes, but nothing happened...Unsure
tph
Denmark
Posts 161
tph replied on Fri, Dec 30 2016 1:20 PM
CB:
I asked about that at my local B&O store. According to them, it's not a display but it's the infrared receiver for remote control. Quite large at that.
— Tuomas | Bang & Olufsen | Bang & Olufsen Create
CB
> You are Here <
Posts 1,762
CB replied on Fri, Dec 30 2016 3:15 PM
Thank you for your post, but it really looks like a display...
[Edit] it seems your dealer is right
Difficult to read, but it's written "window for sensors and antennas"
Page 4 of 4 (137 items) < Previous 1 2 3 4 | RSS
