Looking for a Beolab 3500 wall bracket
arlequin: Looking for a Beolab 3500 wall bracket
Hi and welcome to beoworld.
Which part of the world are you located in?
Do you need the entire bracket assembly? (eg if your BL3500 is currently mounted on a table stand) or do you just need the part that fixes to the wall?
Either way I may be able to help but I would need to check what I've got stored away.
Kind Regards,
