Does anyone know about software 1.2 on a early type 43xx 2 way AV9000 set?
From what i have found out on here, the original 2 way versions types 43xx had software 1.0 and 1.1.
My 1994 type 43xx is one of the last 2 way sets, it was sold to me from its original owner who told me it once had a Beolink 5000 remote, but he later bought some newer B&O kit to connect to it which needed a Beo4 remote (one way)
The original selling B&O dealer seems to have updated the software as a small sticker with 1.2 has been stuck over the original sticker which says 1.1 underneath.
The 1.2 software seems to work with both a 2 way beolink 5000 remote and the 1 way beo4 remote.
My question , is software 1.2 a version that will work both a one way and 2 way remote in full?
I have just bought an original STB-C kit for the AV9000 and MX range and hope to get rid of the humax box out of sight, thing is, this STB kit says it works with AV9000's type 79xx which are the 1995 onwards Beo4 one way sets.
I'm hoping the 1.2 software chips will work my set in both 2 way and the STB-C kit using the beo4 remote for the digital TV part.
Got a Beolink 7000 and 5000 remote i really wish to keep using with this set.
Any info would be great on 1.2 chips
regardsPhil
