MCL2A Speaker protection setting ?
This post has 1 Reply | 0 Followers
Weebyx
Denmark
Posts 1,213
Weebyx Posted: Fri, Jan 15 2016 9:16 AM
Hi all..
What is the speaker protection potentiometer on the MCL2A used for, and what should it be set to ?
I have attached a set of 2 CX100 to a newly aquired MCL2A, but the setting is set to the lowest setting (20w) if I remember..
Cannot seem to find information other than "it should be set correct according to speakers" :)
/Weebyx
Guy
Warwickshire
Posts 2,590
Guy replied on Fri, Jan 15 2016 7:42 PM
From the manual:
The adjustment should be to the 'rated power handling capacity of the speakers.  If the volume is increased beyond the set value, an electronic circuit will automatically switch off the speakers in that room only.'
You can therefore also use to control max permissible volume, eg in a teenagers room!
Page 1 of 1 (2 items) | RSS
