Hi, having trouble with the timer. The player turnes it's self of.
Could someone please explaine how i can turn of the timing mode?
My family is going crazy when it sudenly starts to play or turn itself off.
Hi there, have you tried pressing and holding mute and then pressing 'step' (I.e. Both sides of the control panel)? A red light should come on that says 'timer off'.
if that doesn't work I'm afraid you might have to but a beolink 7000 remote to access timer programming and cancel those timers. The timer programming on these amps is really powerful (including ability to control lighting etc) but can only be done with a two way remote.
Hmmm thanks for replay.
i can not find mute or step buttons on the beocenter 7000. When I bought this player I did not have this problem, but after I was finished pushing buttons I had sett the timer on. Don't know how I did it...
A Beocenter 7000 is not a Beomaster 7000.
I suggest you unplug the Beocenter from mains for a minute or two.If it still acts up, check your remote control or bring the remote control to a different room to rule it out.
Oops! My bad - should have read the question more carefully- disregard the previous, it applies to the beomaster 7000 not beocenter 7000.
