Can Essence be configured to default use the BeoVision connected BeoLab speakers?
This post has 13 Replies | 1 Follower
Flere
Netherlands
Posts 345
Flere Posted: Mon, Jan 18 2016 7:26 PM
If I connect an Essence to my network and I do not connect speakers to this Essence, can the Essence then be configured such that it default uses via NL the BeoLab speakers connected to the BeoVision Avant?
I have read in the Moment user manual ("You can use BeoSound Moment with both wired and wireless speakers or integrate it with your Network Link TV. ") that with the Moment this is possible. It will see via NL the BeoLab's connected to the BeoVision and these speakers can then be selected as default output device.
Can this also be done with the Essence?
- Flere
smile and enjoy the moment
Millemissen
Flensborg, Denmark
Posts 14,680
Flere:
No!
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Mon, Jan 18 2016 9:12 PM
Hi Flere,
I mistakenly believed this was possible until recently, but MM is correct - the Moment can be configured to do this but unfortunately the Essence cannot.
It's a shame as it would be a nice feature and maybe it will be added in the future but I wont be holding my breath.
Martin.
Sal
California, USA
Posts 1,197
Sal replied on Tue, Jan 19 2016 12:03 AM
If you hadn't already read it, here's my post about how the Essence behaves in my system, and it "almost" does what you're looking for.
Flere
Netherlands
Posts 345
Flere replied on Fri, Jan 22 2016 10:16 PM
Thanks Sal. As you say, almost. But not what I am looking for.
- Flere
petrosbeli
Posts 64
There is an update to the BeoSound Essence SW (v.1.4.311) that now supports this setup of integrating an Essence with a BeoVision TV, in such a way that the speakers are on the TV (not the Essence)
See here: http://www.bang-olufsen.com/en/customer-service/product-support/sound-systems/beosound-essence,-,2nd,-,generation
And here: http://bogo.custhelp.com/app/answers/detail/a_id/13858/kw/13858
Note, however, that AirPlay and Spotify Connect are not supported in this setup.
Hiort
Sweden
Posts 2,895
Hiort replied on Wed, Feb 10 2016 10:17 AM
petrosbeli:
Well done B&O. Awesome that the products continue to evolve and brings further value to the existing customers.
Millemissen
Flensborg, Denmark
Posts 14,680
Bravo B&O!
My Essence however, wasn't updated yet.
Yes - it is set to automatic update.
petrosbeli
Posts 64
petrosbeli replied on Wed, Feb 10 2016 11:50 AM
The Essence is checking for an automatic update every night...
But also if you go in the BeoSetup App you should be able to see that there is an update available, to manually push for the update now.
You cant see that?
By the way, we are talking about Essence 2nd. generation, in this context
jans
Belgium
Posts 394
jans replied on Mon, Jun 27 2016 9:06 PM
petrosbeli:
I am thinking of buying An Essence to connect to my V1, and the Beolab 9's connected to the V1.
However, I understand that you cannot use Spotify in this setup. Is there a workaround as I am using spotify a lot.
Or should I switch to Deezer?
Flere
Netherlands
Posts 345
Flere replied on Mon, Jun 27 2016 10:34 PM
jans:
There is no work around yet for using Spotify Connect on an integrated Essence+BeoVision configuration.
But if you use Spotify on you iPad and then use Bluetooth towards the Essence it will work fine.
- Flere
Millemissen
Flensborg, Denmark
Posts 14,680
@jans
....or you could use a Gramofon or a Google Cast Audio device connected to the line-in of the Essence in order to get Spotify Connect on your system.
No integration, though - but a reasonable 'workaround'.
Another would be to connect a Playmaker (another AirPlay receiver) to the line-in of the Essence.
Or use the AppleTV box or an AirPort Express connected directly to the V1.
elephant
AU
Posts 8,219
elephant replied on Tue, Jun 28 2016 10:42 AM
Millemissen:
Or now with latest Essence s/w update use its own building Google cast ????
Only asking because I know nothing about Google cast in this for .....
BeoNut since '75
Flere
Netherlands
Posts 345
Flere replied on Wed, Sep 28 2016 11:38 PM
elephant:
Only asking because I know nothing about Google cast in this for ..... BeoNut since '75
On my integrated Essence it does not seem to work. I can select the Essence in the Deezer app on my iPad via Google Cast, but on the Avant55 an error message is displayed and no sound coming out of the speakers.
- Flere
Page 1 of 1 (14 items) | RSS
