currently I have an Apple TV (3rd gen) hooked to a BV10-32 and remote controlled via PUC from my tried and trusted old Beo 4.
I have looked at the 4th gen ATV and like it. But it seems (and I am seeking for confirmation or correction here) that its remote control talks bluetooth instead of IR. Which in turn would mean, I had to use two remote controls for the set up (Beo 4 for the BV, Apple Remote for the ATV). Right or wrong (e.g. can ATV 4 be remote controlled in the same way as the 3rd gen ATV)?
Would a Beo 5 or 6 fix this?
cheers
Torsten
The ATV4 has ir-support as well.
You only have to replace the 3 with the 4 and you are good to go.
Of course you won't be able to use Siri etc just using the Beo4.
There has been several posting about this on the forum - so that is confirmed from several users.
That's good news. Thanks for the quick reply.
Turning off the ATV4 while switching the source (ATV4 to DVD) seems not working anymore. LED flashs and gets off but gets on again and ATV is still up and running. This wasn't the case with ATV3. Does anybody experienced the same behavior?
Thanks a lot for any comment
Reto
Reto:Turning off the ATV4 while switching the source (ATV4 to DVD) seems not working anymore. LED flashs and gets off but gets on again and ATV is still up and running. This wasn't the case with ATV3. Does anybody experienced the same behavior? Thanks a lot for any comment Reto
BeoNut since '75
