The Beogram 6000, which was made for this receiver is good but so is the tangential 6002, which is belt drive but is really a 4002 in new clothes. Usually very cheap and an excellent deck.
Both will work via the remote control, if you have one!
Peter
Had a quick look on a well known auction site! QDA are selling a 6002 - but are asking £475, which is about 5x what I would value it at. There is a shabby 6006 (linear drive - good but complicated!!) which looks cheap! A 5005 is also not bad, and a 5000, which could well be the pick of the lot.
The radial tracking B&O decks are very common compared to the linear trackers - the mechanics are the same depending on the vintage and easy to fix, while they sound good and would work well on a day to day basis.
I have used a Beogram 1902 with great pleasure, as with the later Beogram 1800.
Edit: The Beogram 5000 that Peter links to is basically the same as the Beogram 1800 - reliable stuff that can be remote-controlled with your Beomaster 6000
Vinyl records, cassettes, open reel, valve amplifiers and film photography.
