Beogram CD 5500 Don't play anymore :(
zenilygy
Posts 18
zenilygy Posted: Sun, Jan 24 2016 2:37 PM
Hello,
Today i picked up a good working (i see) Beogram CD 5500 from Germany.
When i come home i open the cover and clean the laser with a tip and alcohol 96% (do this more than 20 years with no problem)
Also i remove dust from the pcb with contact spray.
I set the player to my set and now it does not play anymore :(
the cd load and the cd spin and i check the red laser light but the player goes back in standby.
any suggestions?
I hear the motor a little bit growl.
But i drive more than a hour. maybe wait that everything is on correct temp?
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, Jan 24 2016 6:53 PM
Replace capacitors on the servo board.
Check the main board for cracked solder joints, particularly at the connectors and the voltage regulators.
Page 1 of 1 (2 items) | RSS
