Hi all,I changed to an A6/4G from my old Audi A6/4F. My problem is strange, Serene worked fine with A6/4F MMI 2G, but works really annoying with the A6/4G MMI 3G. With the former MMI version the address book was perfectly imported, all the numbers appeared in the Audi MMI telephone book without any questions or problems.My current problem is, that with MMI 3G I can synchronise only the first 51 telephone numbers, but non of the others. After the 51 telephone number the MMI stops reading, and Serene gives me a message: "Do you want to allow Audi to access to your data files?" or something like this, but even I press the Green button, it seems that Serene rejects the sharing, and the Audi MMI stops the data import.Honestly, I've never ever seen such a message from Serene, and I didn't found any option in the menu to permanently allow the connection to share these information, mostly because I don't understand the 51 number limit as these informations are even stored on the SIM card, even in the Phone's memory, there is no reason to allow to share the first 51 numbers and deny the sharing the remaining numbers.
Of course the pairing is perfect, and the Audi MMI was authorised in the Bluetooth menu.I know it's a very unusual problem, but maybe somebody has an idea on how can I solve this issue.Thanks in advance for any help or idea :)
