B&O 5000 and Pmc
xavierbangbang
Posts 3
xavierbangbang Posted: Tue, Jan 26 2016 9:27 PM
Hello All
I was lucky enough to buy at a very reasonable price a whole B&O model 5000 with speakers.
I found later a PMC (panel master control) on ebay. The pmc seems to work (leds on) but doesn't seem to control the hifi. Could it be the infra red that is out of order or shall I activate smthg somewhere?
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Jan 26 2016 9:38 PM
Welcome to Beoworld !
First make sure that the MCP (Master Control Panel) is correct for the Beomaster receiver;
If you have a Beomaster 5000, you need MCP 5000.
Beomaster 5500 needs MCP 5500.
They are not interchangeable!
xavierbangbang
Posts 3
Thanks Martin for this start
Yes the MCP and Beomaster are both 5000.
I was wondering if there's a switch to active or something else? the MCP shows "no transmission" message.
xavierbangbang
Posts 3
Page 1 of 1 (4 items) | RSS
