Which Beolab? Beolab 1, Beolab 14, maybe 8000 or Beolab 3?
imac666
Posts 8
imac666 Posted: Fri, Jan 29 2016 6:45 AM
I want to complete my surround setup.
Now I am using a BV 4-50 with Beolab 7.1 and the Beolab 6000.
Which of the speakers would be the best "value" for money?
The 6000s would go back us surround.
To be honest I am not a great fan from the Beolab 3 because I find them ugly.....
So what do you say?
The speakers are for sure for movies an also for music (from Rock to Classic).
Hope you can help me with your exerience.
Andrew
Frinton, UK
Posts 917
Andrew replied on Fri, Jan 29 2016 12:28 PM
Visually the 8000's would go well and sound really good - if you want more bass add a sub later - some of it will depend on the size of your room, decor etc - ih big with high ceilings then beolab 1 if you like the look of them, but my choice would be 8000's
imac666
Posts 8
imac666 replied on Fri, Jan 29 2016 6:29 PM
Thank you Andrew :-)
I started this thread in the german forum too and some of the guys recomend the Beolab 14 (or Beoplay S8).
The 8000s are also a solution but I need for them an extra sub and a wall mount.
The Beolab 1 should be very susceptible to interference?
Page 1 of 1 (3 items) | RSS
